Hello,
Has anyone ever managed to run any of the qtpyvcp GUIs (e.g. Probe Basic, qtdragon, woodpecker) in a Raspberry Pi 4B+8GB with LCNC 2.9.0-Pre on a 64-bit distro? If so, would you mind pointing me in the right direction as to the steps I should attempt?
Long story short, after several days worth of tweaks, forum crawling, SD card reimaging, package and library (re)installations, etc., the issue seems to boil down to not being able to install the version of VTK expected by qtpyvcp.
I'm starting to believe that QtVCP/QtPyVCP cannot run on the RPi4B/8GB (and Kiddekanin wrote that it may be due to the Raspberry Pi using OpenGL-ES while QtVCP requires OpenGL:
forum.linuxcnc.org/9-installing-linuxcnc...blem?start=30#202345
)... But I'd like to hear the experts' opinions before giving up on those nice GUIs on the Pi. I'll happily provide more details if that can be useful to debug.
Thanks for any guidance!
PS: New to the forum; I posted here to avoid creating a new topic, although I'm not certain whether this is a Raspberry Pi or a QtPyVCP issue.
