Probe Basic is it compatible with Python3?
09 Sep 2021 14:20 #220077 by robertspark
Probe Basic is it compatible with Python3? was created by robertspark
As per the title, I was wondering if Probe Basic is compatible with Python 3
The QtPyVCP + Probe Basic documentation seem to mention Debian 9 and Python 2.7
No mention of a clean install for debian 11 and a RIP install of linuxcnc of current master from git
Thanks,
09 Sep 2021 16:56 - 09 Sep 2021 17:01 #220086 by Joco
There is a py3 version. But probably need to get from the repo.
github.com/kcjengr/probe_basic/tree/python3
Cheers - J.
Last edit: 09 Sep 2021 17:01 by Joco.
The following user(s) said Thank You: robertspark
04 Oct 2021 21:39 #222238 by spumco
Replied by spumco on topic Probe Basic is it compatible with Python3?
Robert - did you manage to get the Python 3 compatible version of PB installed?
If so, would you mind walking me through the process?  I'm stumbling around trying to digest this new universe.
Thx,
Ralph
04 Oct 2021 23:13 #222241 by robertspark
Replied by robertspark on topic Probe Basic is it compatible with Python3?
hi Ralph, I am away for a couple of days, I will be back over the weekend, yes happy to go through it no problem
04 Oct 2021 23:34 #222242 by spumco
Thanks Robert, at your convenience.
Trying to get away from UCCNC, but I think I've underestimated the emotional investment required.
05 Oct 2021 01:10 - 05 Oct 2021 01:27 #222250 by TurBoss
Replied by TurBoss on topic Probe Basic is it compatible with Python3?
Hello,
    you can install development version of probebasic with python3 support but still in testing
git clone -b python3 github.com/kcjengr/probe_basic.git
cd probe_basic
python3 -m pip install qtpyvcp
python3 -m pip install -e .
then you could find sample configs under probe_basic/config/probe_basic
and run linuxcnc probe_basic.ini
Last edit: 05 Oct 2021 01:27 by TurBoss.
The following user(s) said Thank You: Roguish, spumco
05 Oct 2021 18:59 - 05 Oct 2021 19:01 #222321 by spumco
Thanks for the assist, but it didn't work for me.  Got an error message "could not find file...probe_basic.ini"
I'm quite sure I'm doing something wrong, but of all the steps I really can't figure out where I'm going wrong.
I did get 2.8.2 installed, and probe basic installed, but started getting errors on that and other GUI's.
Tried again from scratch (clean MX install) today and followed your instructions below.  No joy.
Last edit: 05 Oct 2021 19:01 by spumco.
05 Oct 2021 19:27 #222322 by Joco
spumco - just to make sure on the same page.
 Linuxcnc 2.8.x is only compatible with python2.  If you have installed GUIs as python3 installs they will not work with Linuxcnc 2.8.x.
If you want to use ProbeBasic under python3 then you will need to have installed a python3 capable version of Linuxcnc.   My understanding is that linuxcnc 2.9.x is now pyyhon3.
Thanks.
05 Oct 2021 19:43 - 05 Oct 2021 20:46 #222323 by spumco
Joco,
Again, thanks.  When I mentioned that I installed 2.8, that was two days ago.  As of this minute, I've got 2.9 back on it.
2.8xx requires python2
2.9 requires python3
Probe basic 'normal' requires python2
Probe basic (test per TurBoss) requires:
  • python3
  • QtPyVCP for python3
  • LCNC-RIP (I think - according to the WARNING on the QtPyVCP installation page)
    Following the MXLinux install guide to the letter resulted in MX, LCNC 2.9, and python3.
    After that, I tried TurBoss' instructions verbatim, but those didn't install QtPyVCP - or at least when I ran qtpyvcp -h in a terminal all I got was a 'no such file' error.
    Then I went step-by-step in the qtpyvcp installation.  Did the standard installation and no probe basic.  Ran the RIP installation (linuxcnc-dev/scripts/linuxcnc) and no probe basic.
    So I'm sort of stuck.
[edit - added error logs in case somone knows what they mean]
Last edit: 05 Oct 2021 20:46 by spumco. Reason: add error log
The following user(s) said Thank You: Joco
06 Oct 2021 12:09 #222383 by Joco
Did you run the “qtpyvcp -h” after setting the rip run environment?
until you can get that basic test working not a lot of point going further.
Moderators: KCJ, Lcvette
Time to create page: 0.243 seconds
