Probe Basic is it compatible with Python3?
- spumco
- Thank you received: 905
06 Oct 2021 19:26 - 06 Oct 2021 21:03 #222393
by spumco
Replied by spumco on topic Probe Basic is it compatible with Python3?
Yes, "qtpyvcp -h" responded with a list of available run variables.
qtpyvcp -v = QtPyVCP v0.3.19
linuxcnc-dev/scripts/linuxcnc gets the GUI selector panel up. THere are no qtpyvcp sims in the selector panel - just PB at the bottom.
When I start probe basic, I get this screen output:
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/MILL/linuxcnc-dev/configs/probe_basic'
Machine configuration file is 'probe_basic.ini'
Starting LinuxCNC...
File: tool.tbl Unrecognized line skipped:
;Tool Pocket Z Offset Diameter Remark
twopass:invoked with <> options
twopass:found ./hallib/core_sim_5.hal
twopass:found ./hallib/spindle_sim.hal
twopass:found ./hallib/simulated_home_probe_basic.hal
twopass:found ./hallib/sim_cannon.hal
Note: Using POSIX realtime
motion.c: Creating unlock hal pins for joint 4
File "/home/MILL/.local/bin/probe_basic", line 11, in <module>
load_entry_point('probe-basic', 'gui_scripts', 'probe_basic')()
File "/home/MILL/probe_basic/probe_basic/__init__.py", line 18, in main
vcp_version=__version__)
File "/home/MILL/.local/lib/python3.7/site-packages/qtpyvcp/utilities/opt_parser.py", line 98, in parse_opts
raw_args = docopt(doc, version=version_str)
File "/home/MILL/.local/lib/python3.7/site-packages/docopt.py", line 560, in docopt
pattern = parse_pattern(formal_usage(DocoptExit.usage), options)
File "/home/MILL/.local/lib/python3.7/site-packages/docopt.py", line 375, in parse_pattern
raise tokens.error('unexpected ending: %r' % ' '.join(tokens))
docopt.DocoptLanguageError: unexpected ending: ')'
task: 178 cycles, min=0.000009, max=0.010398, avg=0.008422, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/MILL/linuxcnc_debug.txt
and
/home/MILL/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
and
Last edit: 06 Oct 2021 21:03 by spumco. Reason: added error msgs
- Joco
- Thank you received: 327
06 Oct 2021 23:27 #222411
by Joco
Replied by Joco on topic Probe Basic is it compatible with Python3?
That reads like an error with the python script. It might be an issue with python versions or that particular commit has an error.
- spumco
07 Oct 2021 00:17 #222413
by spumco
I gave up (again) and wiped everything (again).
I've got MX, 2.8, and PB appears to be running. QtVCP doesn't work, but I'm so tired of this I'm going ignore qtvcp and get back to figuring out how to set this up in axis and then PB.
I'll start a new thread when the next crisis hits.
Thanks,
Ralph
Thanks,
Ralph
- Joco
07 Oct 2021 00:37 #222415
by Joco
Qtvvp or qtpyvcp?
not familiar with this MX flavour so not really sure what the problems could be.
- spumco
07 Oct 2021 01:35 #222418
by spumco
QtVCP - used for Silverdragon GUI and other VCP's. That one is broken.
QtPyVCP is working... or at least not throwing errors yet.
- phillc54
- Thank you received: 2100
07 Oct 2021 02:01 #222419
by phillc54
Replied by phillc54 on topic Probe Basic is it compatible with Python3?
QtVCP works fine on MX28 with master branch (Python3) if you run the qtvcp install script.
- spumco
07 Oct 2021 03:07 #222421
by spumco
Thank you Phill.
Yes, QtVCP was working fine on master branch when I had that installed. But I simply couldn't get master working with QtPyVCP and Probe Basic.
Everyone here has been very helpful, but nothing has worked all the way through. I can't count how many iterations and variations I've tried. This forum is littered with my various failures, errors, and frustrations over the past week or so.
Right now, MX, 2.8.2, QtPyVCP, Python(some version), and Probe Basic appear to be playing ok at the moment. I'm in the middle of cleaning up my HAL file a little after running pncconf and I'll see if I can get something to turn on.
If anyone has a magic solution I'm happy to do whatever he (or anyone else) tells me to do, but I'm tired of failing.
-R
-R
- phillc54
07 Oct 2021 03:28 #222423
by phillc54
- spumco
07 Oct 2021 04:00 #222424
by spumco
Let me re-phrase: I broke QtVCP in some way.
I'm becoming convinced that I have the Anti-Midas touch regarding LCNC. Everything turns not to gold... but a more brown hue.
Sorry I can't help with QtPyVCP or Probe Basic.
- spumco
07 Oct 2021 04:05 #222425
by spumco
I did try running the qtvcp install script for 2.8 from your instructions. Got an error during the script (same error as reported by someone else, can't find the thread).
Moderators: KCJ, Lcvette
Time to create page: 0.335 seconds
