(Solved) QtPyVcp in Python3.9 venv issues
5 years 1 month ago - 5 years 1 month ago #221522 by isaac
Last edit: 5 years 1 month ago by isaac.
5 years 1 month ago #221526 by TurBoss
if you built linuxcnc from sources
source linuxcnc/scripts/rip-environment
5 years 1 week ago #223912 by HarryXS
OK, after a long run I finally got it running on a Raspberry PI 4 4GB 64bit OS with the actual linuxcnc master and qtpyvcp.
I think it was too early as stated, with the recent linuxcnc master it works!
Btw. I managed to get gcodebackplot to run on the Raspberry Pi4 64bit with more than 60fps and V3D!
I'll share it with you as soon I cleaned it up and fix a strange bug after loading the gcode file, I'm not able to jog manually anymore...
I close this thread as solved
Cheers, Harry
5 years 1 week ago #223914 by HarryXS
Hmm, cant close the thread and mark it as solved...
someone a hint?
Moderators: KCJ, Lcvette
Time to create page: 0.342 seconds
