Probe Basic main screen doesn't show loaded toolpath
- Lcvette
- Thank you received: 783
27 Jan 2022 18:37 #233297
by Lcvette
Replied by Lcvette on topic Probe Basic main screen doesn't show loaded toolpath
can you try changing the backplot preview by selecting X View on the left side of the plotter window. wondering if it may be a refresh issue.
what gcode file are you trying to load? is it an example or one of your own? is the issue the same with the example files?
- blauerklappstuhl
- Thank you received: 6
27 Jan 2022 18:57 #233299
by blauerklappstuhl
Replied by blauerklappstuhl on topic Probe Basic main screen doesn't show loaded toolpath
i tried my own gcode ,created gcode fom conversational and the arcspiral from pb_examples.
pressing x-view and all other buttons doesnt let the loaded path appear
- MoshKopp
27 Jan 2022 19:20 #233301
by MoshKopp
Replied by MoshKopp on topic Probe Basic main screen doesn't show loaded toolpath
can you start linuxcnc via Terminal and paste your startup entrys here.
- blauerklappstuhl
27 Jan 2022 19:37 - 27 Jan 2022 19:39 #233304
by blauerklappstuhl
got error about too much links, so i pasted in a textdocument:
Last edit: 27 Jan 2022 19:39 by blauerklappstuhl.
- MoshKopp
27 Jan 2022 20:40 #233307
by MoshKopp
Hmm,ok no warnings about VTK is thrown. strange
- Lcvette
29 Jan 2022 22:04 - 29 Jan 2022 22:05 #233491
by Lcvette
blauerklappstuhl,
im wondering if maybe it is a language issue can you test in english? if it works that will give us a narrowed window of where to hunt down the issue in vtk.
or post a non translated version of the gcode files so we can experiment.
thanks,
Chris
thanks,
Chris
Last edit: 29 Jan 2022 22:05 by Lcvette.
- Lcvette
30 Jan 2022 23:05 #233592
by Lcvette
i got a py2 deb10 dev machine setup and starting looking and this machine is also experiencing the failed plottr draw on program load. will need to dig into it and see what is breaking or what changed. it is quite odd because that branch ha been static for a very long time. im wondering if an update to something else has broke it..
I will update here once it is resolved and a fix has been pushed out for update.
Chris
Chris
The following user(s) said Thank You: blauerklappstuhl
- blauerklappstuhl
01 Feb 2022 00:00 #233674
by blauerklappstuhl
Hey Chris,
thank you for your investigation
perhaps some other people with this issue think for a long time its "normal" to just see the machinetravel like i did
Alex
Alex
- Lcvette
01 Feb 2022 02:09 #233680
by Lcvette
I suspect this is being caused by an update in linuxcnc. It is effecting the g and m code status channels also which are used in vtk backplotter. I have a machine that has not been updated for a while that is still running correctly and now one that is new with the issue. The branch that you installed has not been touched for a very long time and was working correctly until recently with no changes made to it. So their is likely a linuxcnc conflict happening is my best guess.
- Lcvette
02 Feb 2022 15:22 #233805
by Lcvette
Ok after middling around trying to find the issue, it appears the status is broken in linuxcnc, can repeat issue on axis GUI and vtk pulls from status while loading the program file. So I suspect this is the culprit. Hopefully someone can resolve soon I am letting them know of the issue now in case it has not been reported.
Moderators: KCJ, Lcvette
Time to create page: 0.305 seconds
