Expand tool table for x and y Offset
26 Nov 2021 06:08 #227641 by icy
Hello,
how can i expand the tool table settings, in the way, that an y and y offset would be possible ?
I need this for an 3d probe to set an referenze point for estimating z with the 3d probe
best regards
Chris
26 Nov 2021 06:41 #227642 by bevins
Replied by bevins on topic Expand tool table for x and y Offset
Hello,
best regards
Chris
I'm not sure I understand what your looking for. There is X Y offsets in tool table.
26 Nov 2021 07:51 #227648 by icy
Replied by icy on topic Expand tool table for x and y Offset
Thats the problem, there is only Z offset in my case, x and y are missing. If i check the tool.tbk, there are only Z entries.
26 Nov 2021 08:07 #227652 by bevins
run axis and check. The offsets should be there. What gui are you using?
Check from file /tool table
26 Nov 2021 08:50 - 26 Nov 2021 08:52 #227655 by anfänger
Replied by anfänger on topic Expand tool table for x and y Offset
Take a look at the config or yaml files you can define what columns you want to have there. At least for probe basic.
www.qtpyvcp.com/plugins/tool_table.html
Last edit: 26 Nov 2021 08:52 by anfänger.
The following user(s) said Thank You: TurBoss
29 Nov 2021 06:06 #227891 by icy
Thanks for the link, but i am not understanding how i have to integrate the parts into the .yml . Maybe someone would be so nice and can post an example how to integrate the tooltable part ?
I ve tried a lot of configurations, but no one worked.
29 Nov 2021 13:01 #227938 by anfänger
search for the probe_basic.yml file in your prob basic folder and replace the toot table entry to:
tooltable:
provider: qtpyvcp.plugins.tool_table:ToolTable
kwargs:
columns: TXYZDR
this might get overwritten once you update.
I am not sure but you might also be able to add this to you custom_config.yml file in your config folder.
30 Nov 2021 07:14 #228001 by icy
If i add
to my my custom_config.yml
nothing will happen. the custom_config.yml in set in the maschine.ini
01 Dec 2021 08:47 #228128 by icy
I am using
example of a machine specific settings
windows:
  mainwindow:
    kwargs:
      confirm_exit: false
settings:
  # VTK backplot view settings
  backplot.show-grid:
    default_value: false
  backplot.show-program-bounds:
  backplot.show-program-labels:
  backplot.show-program-ticks:
  backplot.show-machine-bounds:
  backplot.show-machine-labels:
  backplot.show-machine-ticks:
  backplot.perspective-view:
  backplot.view:
    default_value: P
    options: ["X: Front View", "XZ: Lathe View", "XZ2: Lathe View", "Y: Front View", "Z: Top View", "Z2: Bottom View", "P: Isometric"]
  backplot.multitool-colors:
    default_value: True
data_plugins:
  status:
    kwargs:
      cycle_time: 15
  tooltable:
    kwargs:
        columns: TXYZDR
        file_header_template: |
        LinuxCNC Tool Table
  persistent_data_manager:
    provider: qtpyvcp.plugins.persistent_data_manager:PersistentDataManager
    kwargs:
      # serialization method to use: json or pickle
      serialization_method: pickle
      # persistence_file: .vcp_data.json
  hal:
    provider: qtpyvcp.plugins.exported_hal:ExportedHal
this setting in my .yml, but there i am getting an error yaml.scanner.ScannerError: mapping values are not allowed here in unicode string , line 2 , culumn 8.
After that error Linuxcnc is not loading, and aborting.
Hans anyone an idea, that to do here ?
15 Dec 2021 13:15 #229154 by Stud54
Replied by Stud54 on topic Expand tool table for x and y Offset
Any news here?
I also have just the Z value....no X and Y...
Moderators: KCJ, Lcvette
Time to create page: 0.211 seconds
