Expand tool table for x and y Offset
4 years 11 months ago #227938 by anfänger
search for the probe_basic.yml file in your prob basic folder and replace the toot table entry to:
tooltable:
provider: qtpyvcp.plugins.tool_table:ToolTable
kwargs:
columns: TXYZDR
this might get overwritten once you update.
I am not sure but you might also be able to add this to you custom_config.yml file in your config folder.
4 years 11 months ago #228001 by icy
If i add
to my my custom_config.yml
nothing will happen. the custom_config.yml in set in the maschine.ini
4 years 11 months ago #228128 by icy
I am using
example of a machine specific settings windows:   mainwindow:     kwargs:       confirm_exit: false settings:   # VTK backplot view settings   backplot.show-grid:     default_value: false   backplot.show-program-bounds:     default_value: false   backplot.show-program-labels:     default_value: false   backplot.show-program-ticks:     default_value: false   backplot.show-machine-bounds:     default_value: false   backplot.show-machine-labels:     default_value: false   backplot.show-machine-ticks:     default_value: false   backplot.perspective-view:     default_value: false   backplot.view:     default_value: P     options: ["X: Front View", "XZ: Lathe View", "XZ2: Lathe View", "Y: Front View", "Z: Top View", "Z2: Bottom View", "P: Isometric"]   backplot.multitool-colors:     default_value: True data_plugins:   status:     kwargs:       cycle_time: 15   tooltable:     provider: qtpyvcp.plugins.tool_table:ToolTable     kwargs:         columns: TXYZDR         file_header_template: |         LinuxCNC Tool Table   persistent_data_manager:     provider: qtpyvcp.plugins.persistent_data_manager:PersistentDataManager     kwargs:       # serialization method to use: json or pickle       serialization_method: pickle       # persistence_file: .vcp_data.json          hal:     provider: qtpyvcp.plugins.exported_hal:ExportedHal
this setting in my .yml, but there i am getting an error yaml.scanner.ScannerError: mapping values are not allowed here in unicode string , line 2 , culumn 8.
After that error Linuxcnc is not loading, and aborting.
Hans anyone an idea, that to do here ?
4 years 10 months ago #229154 by Stud54
Any news here?
I also have just the Z value....no X and Y...
4 years 10 months ago #229162 by anfänger
here s my custom_config.yml
# use custom probe basic main window class
windows:
mainwindow:
provider: custom_probebasic:CustomProbeBasic
data_plugins:
tooltable:
kwargs:
# specify the columns that should be read and writen to the
# tooltable file. To use all columns set to: TPXYZABCUVWDIJQR
columns: PTXYZWDR
# specify text to be added before the tool table data
# example of a machine specific settings
#windows:
# mainwindow:
# kwargs:
# confirm_exit: false
I hope this helps you.
Moderators: KCJ, Lcvette
Time to create page: 0.079 seconds
