Probe Basic / Jog Increment Hal Pins
02 Dec 2021 11:44 #228209 by Jedi
Hallo every one,
im using Probe Basic and it is working great.
Im trying to connect the Jog incremental of the UI with hardware buttons is ther a Hal Pin like in the gmoccapy Gui?
thanks in advands!
Best Regards,
Benedikt
09 Dec 2021 15:17 #228734 by andypugh
Replied by andypugh on topic Probe Basic / Jog Increment Hal Pins
If you start LinuxCNC then open a terminal and type
halcmd show pin *jog*
Then you will get a list of likely pins.
You can then try searching the LinuxCNC docs for each pin to find the description.
Moderators: KCJ, Lcvette
Time to create page: 0.070 seconds
