Probe Basic Lathe on LinuxCNC 2.9
2 years 11 months ago #285824 by rodw
Please note the linuxcnc 2.9 ISO download includes the qtpyvcp repos set up for apt for covenience. you just need to do the usual sudo apt install per the qtpyvcp web site.
This also implies thet if qtpyvcp updates their repos, sudo apt upgrade will get the latest published version...
2 years 11 months ago #285826 by geostein8888
unfortunately apt install python3-qtpyvcp tells me that i already have installed the latest version
root@siridrill:/usr/lib/python3/dist-packages/probe_basic# apt install python3-qtpyvcp
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
python3-qtpyvcp ist schon die neueste Version (4.0-35.dev).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
2 years 11 months ago #285827 by geostein8888
here the info qtpyvcp
root@siridrill:/usr/lib/python3/dist-packages/probe_basic# qtpyvcp -i
QtPyVCP Info
Version: 0+unknown
LinuxCNC Info
Version: 2.9.1
Qt Info
Qt Version: 5.15.8
Qt API: PyQt5
Qt API Version: 5.15.9
System Info
Description: Debian GNU/Linux 12 (bookworm)
Kernel: 6.1.0-13-rt-amd64
Version: #1 SMP PREEMPT_RT Debian 6.1.55-1 (2023-09-29)
Ram: 16 GB
CPU Info
Vendor ID: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Architecture:
Physical Cores: 4
Logical Cores: 4
2 years 11 months ago #285972 by Lcvette
run the uninstall commands below, then follow the installation section from the link below to install the apt version. easy peasy just did this on my machines the other day works perfectly, be sure to rename your config files something other than probe basic so they do not get overwritten during the update. never a bad idea to keep a backup copy somewhere also before running updates just to be safe!
uninstall existing deb installation, run each in terminal in order below to remove without dependency errors:
sudo dpkg -P python3-probe-basic
sudo dpkg -P python3-qtpyvcp
sudo dpkg -P python3-hiyapyco
Next, follow the short instructions here to setup apt:
kcjengr.github.io/probe_basic/quick_start_apt.html
2 years 11 months ago #286003 by geostein8888
i did this already yesterday, but still the same error
Georg
2 years 11 months ago #286036 by der hobbyist
I have a similar issue. I installed the debian12-iso from the linuxcnc download page today. But if I start the Probe basic lathe I get the same error.
I think there is a problem with the probe_basic_lathe.yml  (see the picture below).
Moderators: KCJ, Lcvette
Time to create page: 0.062 seconds
