- User Interfaces
- Other User Interfaces
- QtPyVCP
- Notifications - Can I stop the dialog and move them to a widget in the VCP?
- Donb9261
- Thank you received: 103
25 Jan 2022 07:17 #233062
by Donb9261
Notifications - Can I stop the dialog and move them to a widget in the VCP? was created by Donb9261
The dialog is nice but takes far too much real estate.
It would be nice to know how I could a) stop the dialog from appearing b) use a widget to show the notifications inside the main window and viewable by button press events.
Kurt,
Is this possible and if so where do I begin? I try not to screw around too much with the original code so as not to break the app. Maybe rewrite the notifications widget and label yours as _old? Or have it pick between the 2 types: dialog or main window based on yaml config?
Open too your expert opinion. And sincerely hope you are doing well.
Kurt,
The following user(s) said Thank You: KCJ
- Grotius
- Thank you received: 2349
26 Jan 2022 16:16 #233237
by Grotius
Replied by Grotius on topic Notifications - Can I stop the dialog and move them to a widget in the VCP?
In python add a "#" before the self.dialog pop up ... line.
This takes a Python course.
Attached 2 Python files, doing a similar thing. Loading a window and a button. Maybe interesting to study.
- KCJ
- Thank you received: 267
03 Feb 2022 08:10 #233879
by KCJ
Replied by KCJ on topic Notifications - Can I stop the dialog and move them to a widget in the VCP?
Don,
Notifications are implemented as a plugin, so are extremely easy to modify to suit your needs. To disable you can comment out the notifications plugin in the YAML file.
This is the plugin that sends the desktop notifications:
github.com/kcjengr/qtpyvcp/blob/master/q...ins/notifications.py
Here is a widget that displays the notifications in the GUI:
github.com/kcjengr/qtpyvcp/blob/master/q...tification_widget.py
Cheers,
Kurt
Cheers,
Kurt
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.080 seconds
