QtPyVCP - Missing Libraries - Solved
  • Donb9261
  • Topic Author
  • Elite Member
  • Elite Member
4 years 9 months ago #233877 by Donb9261
QtPyVCP - Missing Libraries was created by Donb9261
Have the QAnimation and other libraries been removed? Currently I cannot even use a QPushButton hover event. I have tried the following for just hover events to no avail:
QPushButton {
    background-color: rgb(0,0,0);
    color: rgb(255,255,255);
QPushButton:hover {
    background-color: rgb(255,255,255);
    color: rgb(0,0,0);
and...
#some_btn {
#some_btn:hover {
    color: rgb(0,0,0);
Neither method works regardless of what I do. Makes little sense to not have the full QtCore library so I am confused as to why it does not perform a basic Qt styling function.
Any help is appreciated. Maybe it is just me not understanding how it works.
4 years 9 months ago #233878 by KCJ
Replied by KCJ on topic QtPyVCP - Missing Libraries
QSS style should work without any issue.
This is how all the QtPyVCP GUIs are styled ...
My guess is there is another style sheet overriding your styles.
How are you applying your QSS?
Look here for an example of sass generated styles for QtPyVCP. This should style basically every widget: github.com/KurtJacobson/monokrom-vcp/blo.../common/monokrom.qss
Cheers,
Kurt
  • Donb9261
  • Topic Author
  • Elite Member
  • Elite Member
4 years 9 months ago #233885 by Donb9261
Replied by Donb9261 on topic QtPyVCP - Missing Libraries
Yeah I thought so as well. The test vcp is run via the ./turtorial.sh method then a standard editvcp xxx.
Any files are the default generated during the script. yaml shows style.qss and there are no additional qss files to my knowledge unless that is placed elsewhere outside the default file locations. The current style.qss file has only defaults for action buttons which I assume are custom widgets that fall outside the override of a QPushButton.
My current build is through the exact methods described in the dev install for Bullseye. I am currently running my system defaulted to the versions required to run master. Ohter than that my system is barebones as you can get.
At first I thought GNOME interference but tried gtk2 and 3 under cinnamon with the same result. Just odd.
And like I said I cannot get the QtAnimation libraries to load without error with PySide2 or PyQt5.
Just odd and a bit frustrating. Lol!
  • Donb9261
  • Topic Author
  • Elite Member
  • Elite Member
4 years 9 months ago #233886 by Donb9261
Apparently I had a corrupt file. I recreated from scratch and now hover works.
  • Donb9261
  • Topic Author
  • Elite Member
  • Elite Member
4 years 9 months ago - 4 years 9 months ago #233930 by Donb9261
Replied by Donb9261 on topic QtPyVCP - Missing Libraries - Solved
Here is the link on YouTube.
Last edit: 4 years 9 months ago by Donb9261.
Moderators: KCJ, Lcvette
Time to create page: 0.168 seconds
