Probe Basic program run time stays 0:00:00
- cheburs
06 Apr 2022 22:47 #239477
by cheburs
Probe Basic program run time stays 0:00:00 was created by cheburs
Timer doesn't start when i run gcode and always stays 0:00:00
Have added in .iniand
time.hal contains:
My config - github.com/kriksis/Thor-cnc-7i76
Thnaks!
Have added in .ini
POSTGUI_HALFILE = hallib/time.haltime.hal contains:
loadrt time
loadrt not
addf time.0 servo-thread
addf not.0 servo-thread
net prog-running not.0.in <= halui.program.is-idle
net cycle-timer time.0.start <= not.0.out
net cycle-seconds qtpyvcp.timerseconds.in <= time.0.seconds
net cycle-minutes qtpyvcp.timerminutes.in <= time.0.minutes
net cycle-hours qtpyvcp.timerhours.in <= time.0.hoursMy config - github.com/kriksis/Thor-cnc-7i76
Thnaks!
- Lcvette
- Thank you received: 784
06 Apr 2022 23:24 #239479
by Lcvette
Replied by Lcvette on topic Probe Basic program run time stays 0:00:00
What version? If this is 2.9 master py3 branch time is not used anymore and you need to use the probe_basic post GUI Hal file instead, the time code is now in there
- cheburs
06 Apr 2022 23:44 #239481
by cheburs
Replied by cheburs on topic Probe Basic program run time stays 0:00:00
Its 2.8.2
- Lcvette
11 Apr 2022 19:55 #239967
by Lcvette
you need to condense your post gui files into one file, i think only one can be called. likely why time.hal is not functioning correctly
11 Apr 2022 23:06 - 11 Apr 2022 23:07 #239994
Replied by andypugh on topic Probe Basic program run time stays 0:00:00
You can call a single POSTGUI_HALFILE that contains references to several other HAL files:you need to condense your post gui files into one file, i think only one can be called. likely why time.hal is not functioning correctly
# Ordinary halfile commands
net somesignal somepin someotherpin
# Include HAL from a separate file
source halfile1.hal
# and another file
source halfile2.hal
# and carry on with normal hal-y things
net signel56 pyvcp.0.in1....
Last edit: 11 Apr 2022 23:07 by andypugh.
- cheburs
12 Apr 2022 15:07 - 12 Apr 2022 15:08 #240053
by cheburs
It worked putting all in one postgui file.
Im using vistacnc pendant and in their .hal file there is this line -
and also time.hal uses pin halui.program.is-idle.
I get an error that pin is already linked.
How can i make them both happy?
net program.is-idle halui.program.is-idle => vc-p4s.program.is-idleI get an error that pin is already linked.
Last edit: 12 Apr 2022 15:08 by cheburs.
- GuiHue
- Thank you received: 39
12 May 2022 09:23 #242767
by GuiHue
Replied by GuiHue on topic Probe Basic program run time stays 0:00:00
With halui.program.is-idle being an out pin, simple modifactions of the pin assignment should work:
Delete from above:
replace by:
net program.is-idle not.0.in
You can connect a HAL out pin to multiple IN pins, however, it must be within one signal name. The signal name ist the first part after the net command.
Delete from above:
replace by:
Moderators: KCJ, Lcvette
Time to create page: 0.605 seconds
