PackageNotFoundError qtpyvcp
20 Apr 2022 20:18 #240757 by tripwire
PackageNotFoundError qtpyvcp was created by tripwire
Everything was working fine and I created a nice GUI vcp in qtpyvcp. But after a simple computer restart, I now get the following error when trying to edit my vcp (and similar error if I try to launch the vcp from linuxcnc.)
dave@debianDave:~$ editvcp vcp1
  File "/home/dave/.local/bin/editvcp", line 33, in <module>
    sys.exit(load_entry_point('qtpyvcp', 'console_scripts', 'editvcp')())
  File "/home/dave/.local/bin/editvcp", line 22, in importlib_load_entry_point
    for entry_point in distribution(dist_name).entry_points
  File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 957, in distribution
    return Distribution.from_name(distribution_name)
  File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 548, in from_name
    raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: No package metadata was found for qtpyvcp
other info:
dave@debianDave:~$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux bookworm/sid"
NAME="Debian GNU/Linux"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
dave@debianDave:~$ python3 --version
Python 3.10.4
dave@debianDave:~$ which python3
/usr/bin/python3
Any help in solving this issue will be greatly appreciated, thanks!
21 Apr 2022 03:34 #240777 by MoshKopp
Replied by MoshKopp on topic PackageNotFoundError qtpyvcp
have you copied the xsessionrc ?
Last command in section 4
kcjengr.github.io/probe_basic/dev_install.html
21 Apr 2022 17:11 - 21 Apr 2022 17:36 #240803 by tripwire
Replied by tripwire on topic PackageNotFoundError qtpyvcp
I may have overlooked that. Thanks for the suggestion!
However, the xsessionrc command follows the " python3 -m pip install --editable ." command. So I don't get that far.
When trying to issue " python3 -m pip install --editable ." get the following output (with errors):
dave@debianDave:~/qtpyvcp$ pip3 install --editable .
Defaulting to user installation because normal site-packages is not writeable
Obtaining file:///home/dave/qtpyvcp
  Preparing metadata (setup.py) ... done
Requirement already satisfied: HiYaPyCo in /home/dave/.local/lib/python3.10/site-packages (from qtpyvcp===python3-master-178.g247f6465) (0.4.16)
Requirement already satisfied: MarkupSafe==2.0.1 in /usr/lib/python3/dist-packages (from qtpyvcp===python3-master-178.g247f6465) (2.0.1)
Requirement already satisfied: docopt in /home/dave/.local/lib/python3.10/site-packages (from qtpyvcp===python3-master-178.g247f6465) (0.6.2)
Collecting oyaml
  Using cached oyaml-1.0-py2.py3-none-any.whl (3.0 kB)
Requirement already satisfied: psutil in /home/dave/.local/lib/python3.10/site-packages (from qtpyvcp===python3-master-178.g247f6465) (5.9.0)
Requirement already satisfied: pyopengl in /usr/lib/python3/dist-packages (from qtpyvcp===python3-master-178.g247f6465) (3.1.5)
Collecting pyqtgraph
  Using cached pyqtgraph-0.12.4-py3-none-any.whl (995 kB)
Requirement already satisfied: pyudev in /home/dave/.local/lib/python3.10/site-packages (from qtpyvcp===python3-master-178.g247f6465) (0.23.2)
Requirement already satisfied: qtpy in /home/dave/.local/lib/python3.10/site-packages (from qtpyvcp===python3-master-178.g247f6465) (2.0.1)
Collecting simpleeval
  Using cached simpleeval-0.9.12-py2.py3-none-any.whl (14 kB)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from qtpyvcp===python3-master-178.g247f6465) (1.16.0)
[color=#ff0000]ERROR: Could not find a version that satisfies the requirement vtk (from qtpyvcp) (from versions: none)
ERROR: No matching distribution found for vtk[/color]
I welcome any input on that...
Last edit: 21 Apr 2022 17:36 by tripwire. Reason: new info discovered
21 Apr 2022 18:55 #240806 by MoshKopp
is it possible to start editvcp after you give the Command
export PATH=$PATH:~/.local/bin/
21 Apr 2022 20:14 #240809 by TurBoss
Replied by TurBoss on topic PackageNotFoundError qtpyvcp
Hello,
there is no vtk in pip for python3.10
i has to be built from sources
build vtk python3.10 with QT amd64
sudo apt install build-essential cmake mesa-common-dev mesa-utils freeglut3-dev ninja git-lfs
git clone --recursive gitlab.kitware.com/vtk/vtk.git
cd vtk
cmake -B build -S . -GNinja -DVTK_WRAP_PYTHON=ON -DVTK_PYTHON_VERSION=3 -DVTK_ENABLE_WRAPPING=ON -DVTK_GROUP_ENABLE_Qt=YES -DVTK_QT_VERSION=5
cmake --build build --parallel 2
cmake --install build
build linuxcnc against python3.10 or rebuild if new boost lib in system
install for vtk runtime
libospray libopenvr_api liblas libcgns libadios2_cxx11 libhpdf libboost_python310
run or add this line to your .bashrc
export PYTHONPATH=$PYTHONPATH:/usr/local/lib/python3.10/site-packages/
21 Apr 2022 20:52 #240810 by tripwire
I'll give that a try, thanks!!
21 Apr 2022 22:21 #240827 by tripwire
Well, I ran into a few errors.
dave@debianDave:~/dev$ sudo apt install build-essential cmake mesa-common-dev mesa-utils freeglut3-dev ninja git-lfs
[sudo] password for dave:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package ninja
So I tried the following:
dave@debianDave:~/dev$ sudo apt-get install -y ninja-build
ninja-build is already the newest version (1.10.1-1).
 (a bunch of output)
(etc. ... nothing installed...)
Then:
dave@debianDave:~$ git clone --recursive gitlab.kitware.com/vtk/vtk.git
fatal: repository 'gitlab.kitware.com/vtk/vtk.git' does not exist
So I downloaded a zip file from that site, extracted it and then:
dave@debianDave:~/dev/vtk$ cmake -B build -S . -GNinja -DVTK_WRAP_PYTHON=ON -DVTK_PYTHON_VERSION=3 -DVTK_ENABLE_WRAPPING=ON -DVTK_GROUP_ENABLE_Qt=YES -DVTK_QT_VERSION=5
This produced a lot of output but I got the following errors in the end:
CMake Warning at CMake/vtkModule.cmake:4541 (find_package):
  Found package configuration file:
    /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake
  but it set Qt5_FOUND to FALSE so package "Qt5" is considered to be NOT
  FOUND.  Reason given by package:
  Failed to find Qt5 component "Quick" config file at
  "/usr/lib/x86_64-linux-gnu/cmake/Qt5Quick/Qt5QuickConfig.cmake"
  Failed to find Qt5 component "Qml" config file at
  "/usr/lib/x86_64-linux-gnu/cmake/Qt5Qml/Qt5QmlConfig.cmake"
Call Stack (most recent call first):
  GUISupport/QtQuick/CMakeLists.txt:16 (vtk_module_find_package)
CMake Error at CMake/vtkModule.cmake:4547 (message):
  Could not find the Qt5 external dependency.
-- Configuring incomplete, errors occurred!
See also "/home/dave/dev/vtk/build/CMakeFiles/CMakeOutput.log".
See also "/home/dave/dev/vtk/build/CMakeFiles/CMakeError.log".
Can you specify which packages to install to fix this?
I appreciate your help, thanks!!
21 Apr 2022 23:42 - 21 Apr 2022 23:47 #240839 by TurBoss
> $ git clone gitlab.kitware.com/vtk/vtk.git
try this to get the source and the sub-modules needed to build (zip doesn't include them)
git clone --recursive https://gitlab.kitware.com/vtk/vtk.git
plz try to install this ones
$ sudo apt install qtquickcontrols2-5-dev
Last edit: 21 Apr 2022 23:47 by TurBoss.
22 Apr 2022 01:22 #240847 by tripwire
Thanks again! I'll give that a try tomorrow.
22 Apr 2022 19:12 #240905 by tripwire
Well, I got the same errors doing the cmake. I tried to install Qt from source which seems to be the only open source option. It's HUGE! And I got errors when trying to build Qt.
So, I appreciate the advice you've given me. I think I'm just not Linux savvy enough to fix it if something goes off-script.
So I think I'm going to rewind back to Python 3.9 (if I can figure that out...)
Thanks again!
Moderators: KCJ, Lcvette
