ImportError: cannot import name 'ini' from 'linuxcnc'
- tripwire
- Thank you received: 12
23 Apr 2022 20:09 #241018
by tripwire
ImportError: cannot import name 'ini' from 'linuxcnc' was created by tripwire
I've installed qtpyvcp as per
www.qtpyvcp.com/install/bullseye.html
Everything proceeded without error except for the following:
dave@davesLinuxMachine:~$ qtpyvcp -h
File "/home/dave/.local/bin/qtpyvcp", line 33, in <module>
sys.exit(load_entry_point('qtpyvcp', 'console_scripts', 'qtpyvcp')())
File "/home/dave/dev/qtpyvcp/qtpyvcp/app/__init__.py", line 72, in main
from qtpyvcp.utilities.opt_parser import parse_opts
File "/home/dave/dev/qtpyvcp/qtpyvcp/utilities/opt_parser.py", line 64, in <module>
from linuxcnc import ini
ImportError: cannot import name 'ini' from 'linuxcnc' (unknown location)
It seems a module, opt_parser.py, is looking for a module, linuxcnc.py, in order to import a class, "ini". Is that correct? If so, where should this linuxcnc.py module reside? How does it get installed? Or is there another way to correct this error (without reinstalling the OS.)?
Thanks.
Thanks.
- tripwire
24 Apr 2022 16:58 #241080
by tripwire
Replied by tripwire on topic ImportError: cannot import name 'ini' from 'linuxcnc'
It's strange that I can import linuxcnc but not "ini":
dave@davesLinuxMachine:~$ python3
Python 3.9.12 (main, Mar 24 2022, 13:02:21)
[GCC 11.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import linuxcnc
File "<stdin>", line 1, in <module>
>>> import linuxcnc
- tripwire
24 Apr 2022 17:15 - 24 Apr 2022 17:17 #241086
by tripwire
Zeroing in on my own issue...
>>> import linuxcnc
>>> linuxcnc
<module 'linuxcnc' (namespace)>
>>> dir(linuxcnc)
>>> exit()
dave@davesLinuxMachine:~$ python3.10
Python 3.10.4 (main, Apr 2 2022, 09:04:19) [GCC 11.2.0] on linux
>>> import linuxcnc
>>> dir(linuxcnc)
'ANGULAR', 'AUTO_FORWARD', 'AUTO_PAUSE', 'AUTO_RESUME', 'AUTO_REVERSE', 'AUTO_RUN', 'AUTO_STEP', 'BRAKE_ENGAGE', 'BRAKE_RELEASE', 'DEBUG_CONFIG', 'DEBUG_INTERP', 'DEBUG_INTERP_LIST', 'DEBUG_MOTION_TIME', 'DEBUG_NML', 'DEBUG_RCS', 'DEBUG_STATE_TAGS', 'DEBUG_TASK_ISSUE', 'DEBUG_VERSIONS', 'EXEC_DONE', 'EXEC_ERROR', 'EXEC_WAITING_FOR_DELAY', 'EXEC_WAITING_FOR_IO', 'EXEC_WAITING_FOR_MOTION', 'EXEC_WAITING_FOR_MOTION_AND_IO', 'EXEC_WAITING_FOR_MOTION_QUEUE', 'EXEC_WAITING_FOR_SPINDLE_ORIENTED', 'EXEC_WAITING_FOR_SYSTEM_CMD', 'FLOOD_OFF', 'FLOOD_ON', 'INTERP_IDLE', 'INTERP_PAUSED', 'INTERP_READING', 'INTERP_WAITING', 'JOG_CONTINUOUS', 'JOG_INCREMENT', 'JOG_STOP', 'KINEMATICS_BOTH', 'KINEMATICS_FORWARD_ONLY', 'KINEMATICS_IDENTITY', 'KINEMATICS_INVERSE_ONLY', 'LINEAR', 'MAX_AXIS', 'MAX_JOINTS', 'MIST_OFF', 'MIST_ON', 'MODE_AUTO', 'MODE_MANUAL', 'MODE_MDI', 'MOTION_TYPE_ARC', 'MOTION_TYPE_FEED', 'MOTION_TYPE_INDEXROTARY', 'MOTION_TYPE_PROBING', 'MOTION_TYPE_TOOLCHANGE', 'MOTION_TYPE_TRAVERSE', 'NML_DISPLAY', 'NML_ERROR', 'NML_TEXT', 'OPERATOR_DISPLAY', 'OPERATOR_ERROR', 'OPERATOR_TEXT', 'PREFIX', 'RCS_DONE', 'RCS_ERROR', 'RCS_EXEC', 'SHARE', 'SPINDLE_CONSTANT', 'SPINDLE_DECREASE', 'SPINDLE_FORWARD', 'SPINDLE_INCREASE', 'SPINDLE_OFF', 'SPINDLE_REVERSE', 'STATE_ESTOP', 'STATE_ESTOP_RESET', 'STATE_OFF', 'STATE_ON', 'TRAJ_MODE_COORD', 'TRAJ_MODE_FREE', 'TRAJ_MODE_TELEOP', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'command', 'draw_dwells', 'draw_lines', 'error', 'error_channel', 'gui_respect_offsets', 'gui_rot_offsets', 'ini', 'line9', 'nmlfile', 'positionlogger', 'stat', 'tool', 'version', 'vertex9'
module "linuxcnc" *does" contain "ini" in python3.10 but not python3.9. But I think there are issues with vtk in python3.10.
So...I'll keep you (me) posted...ha! (Feel free, anyone, to weigh in...)
>>> import linuxcnc
>>> linuxcnc
>>> dir(linuxcnc)
>>> exit()
>>> import linuxcnc
>>> dir(linuxcnc)
Last edit: 24 Apr 2022 17:17 by tripwire.
- tripwire
25 Apr 2022 14:31 - 25 Apr 2022 15:27 #241207
by tripwire
Replied by tripwire on topic ImportError: cannot import name 'ini' from 'linuxcnc' - NOT_SOLVED
I'll report back... Looking good so far...
Last edit: 25 Apr 2022 15:27 by tripwire.
- tripwire
25 Apr 2022 14:32 - 25 Apr 2022 15:26 #241208
by tripwire
I'm resorting to reinstalling Debian 11 and *closely* following the installation instructions here:
Last edit: 25 Apr 2022 15:26 by tripwire.
- tripwire
25 Apr 2022 15:49 - 25 Apr 2022 15:51 #241214
by tripwire
In the following steps, line 4:WHY THE HELL AM I WAITING HERE FOR HOURS COMPILING DOCUMENTATION IN A BUNCH OF LANGUAGES I DON'T NEED??????????
cd ~/dev/linuxcnc/rip/debian
./configure uspace
cd ..
dpkg-buildpackage -b -uc
cd ..
Last edit: 25 Apr 2022 15:51 by tripwire.
- tripwire
25 Apr 2022 16:02 #241215
by tripwire
Success!
dave@DavesLinuxMachine:~$ qtpyvcp -i
QtPyVCP Info
Version: python3_master+178.g247f6465
LinuxCNC Info
Version: 2.9.0~pre0
Qt Info
Qt Version: 5.15.2
Qt API: PyQt5
Qt API Version: 5.15.2
System Info
Description: Debian GNU/Linux 11 (bullseye)
Kernel: 5.10.0-13-rt-amd64
Version: #1 SMP PREEMPT_RT Debian 5.10.106-1 (2022-03-17)
Ram: 8 GB
CPU Info
Vendor ID: Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
Architecture:
Physical Cores: 4
Logical Cores: 4
Network
Hostname: DavesLinuxMachine
IP Address: 127.0.1.1
MAC Address: e9:a3:ee:b7:10:8d
The following user(s) said Thank You: TurBoss
- Thank you received: 4152
26 Apr 2022 07:30 #241263
Replied by rodw on topic ImportError: cannot import name 'ini' from 'linuxcnc'
Yeh its annoying. You can add no-docs to the command line to ./configure.In the following steps, line 4:
cd ~/dev/linuxcnc/rip/debian ./configure uspace cd .. dpkg-buildpackage -b -uc cd .. WHY THE HELL AM I WAITING HERE FOR HOURS COMPILING DOCUMENTATION IN A BUNCH OF LANGUAGES I DON'T NEED??????????
The following user(s) said Thank You: tripwire
- tripwire
26 Apr 2022 16:40 #241307
by tripwire
Thanks for the tip, rodw! And I apologize for the slightly vulgar outburst. I was just wrestling with trying to get up and running with qtpyvcp/linuxcnc/debian for a few frustrating days.
But all seems good now.
Moral of the story--follow directions closely the first time!
- tripwire
26 Apr 2022 16:44 #241308
by tripwire
A question comes to mind:
Is it safe to install the updates that Debian 11 suggests? I really don't want to break my qtpyvcp setup...
Moderators: KCJ, Lcvette
Time to create page: 0.176 seconds
