probe basic notification dialogues
24 Jul 2022 02:57 - 24 Jul 2022 02:58 #248151 by Eyecon
probe basic notification dialogues was created by Eyecon
Hello,
I'm running linuxcnc 2.9 on Debian 11(Cinnamon desktop environment) with qtpyvcp and brobe_basic installed from the github source (python3 branches) but I'm having issues with the notification or error dialogues showing almost off screen to the right and cut off when launching probe_basic in full screen mode. My screen resolution is 1920x1080. Are there any settings I can modify to change this behavior?
Last edit: 24 Jul 2022 02:58 by Eyecon.
24 Jul 2022 03:02 #248152 by Lcvette
Replied by Lcvette on topic probe basic notification dialogues
I believe that issue was just corrected, pull the latest updates and should be resolved!
24 Jul 2022 03:12 - 24 Jul 2022 03:13 #248153 by Eyecon
Replied by Eyecon on topic probe basic notification dialogues
Thanks, I installed probe basic from GitHub python 3 branch this afternoon, was it corrected later today?
Last edit: 24 Jul 2022 03:13 by Eyecon.
24 Jul 2022 22:22 #248195 by ddB0515
Replied by ddB0515 on topic probe basic notification dialogues
I have pulled latest from git yesterday and was working for a day, with latest changed again have same issue (reported on Discord but looks like now more people have same issue)
My machine:
And issue you can see in attachment
24 Jul 2022 23:10 #248199 by Lcvette
Did you pull the latest qtpyvcp also?
24 Jul 2022 23:38 #248202 by Eyecon
In my case yes and tried again today, no change.
Also quick question: which yml settings file to I need to change to disable error dialogues in the meantime? I modified the one in the probe_basic folder(the folder from which I did the pip install, present in my user home directory) but it doesn’t seem to be having any impact.
24 Jul 2022 23:41 #248204 by ddB0515
I have tested on separate branch that TurBoss made changes and now they are working for me
You can try it also if you want on qtpyvcp branch: notifications_fix
Let me know if that worked for you so maybe that will be merged soon to master
The following user(s) said Thank You: Lcvette, Eyecon
24 Jul 2022 23:44 #248205 by Eyecon
Will try this branch and report back, so just pull qtpyvcp notificafions_fix branch? No need to pull probe_basic again?
24 Jul 2022 23:45 #248206 by ddB0515
Yes just qtpyvcp no need to do anything with probe basic
25 Jul 2022 00:05 #248208 by tightmopedman9
Replied by tightmopedman9 on topic probe basic notification dialogues
I'm having the same issue with notifications showing up off screen, but I'm running 2.8.2 without Python 3. Is there any fixt that wouldn't require upgrading?
Moderators: KCJ, Lcvette
Time to create page: 0.523 seconds
