Probe Basic spindle load bar off by a decimal
- TurBoss
- Thank you received: 81
07 Sep 2022 21:16 #251441
by TurBoss
Replied by TurBoss on topic Probe Basic spindle load bar off by a decimal
Thanks I edited my post with the correct component names.
The following user(s) said Thank You: Lcvette, masterjuggler
- Lcvette
- Thank you received: 783
07 Sep 2022 22:19 #251445
by Lcvette
Replied by Lcvette on topic Probe Basic spindle load bar off by a decimal
Thanks @Turboss and no worries @masterjuggler glad you got it sorted! can you take a small video of it working? i've still yet to set mine up even though i've bought the component that will capture the amperage and output an analog signal.. but you did remind me i had it on a shelf somewhere so i pulled it out and dusted it off so i could start planning its install!
- masterjuggler
- Thank you received: 6
07 Sep 2022 23:11 - 07 Sep 2022 23:12 #251447
by masterjuggler
Replied by masterjuggler on topic Probe Basic spindle load bar off by a decimal
Attached a quick demo of the spindle load bar working if that helps give motivation lol.
By the way, on a totally unrelated note, how are you supposed to configure the pin display on the status page? I see that I can edit each pin's name and the card names, but I haven't been able to find how to either set them up in the gui or add them to a config file.
EDIT: seems I can't upload a proper video, so I zipped it. Oh well.
Last edit: 07 Sep 2022 23:12 by masterjuggler.
The following user(s) said Thank You: tommylight, Lcvette
- Lcvette
07 Sep 2022 23:15 #251448
by Lcvette
awesome! how is the updating in realtime? is it pretty smooth?
- masterjuggler
07 Sep 2022 23:30 #251450
by masterjuggler
It seems to be updating in real time, if a bit stuttery. But it's entirely probable that's caused by the fact that I'm running LinuxCNC on an AMD Athlon x2 lol.
- daveyr
- Thank you received: 12
23 Oct 2022 00:46 #254812
by daveyr
Replied by daveyr on topic Probe Basic spindle load bar off by a decimal
I have been trying to the same as in this thread but i seem to not be able to find halcompile
For my install i used the joco-nz bullseye installer to install the dev version of probe basic and linuxcnc 2.9
I am not sure if you would be willing to share your compiled version as i also have a 9 amp max for my VFD.
- TurBoss
23 Oct 2022 02:05 #254817
by TurBoss
Hello
To get halcompile you need to install linuxcnc-dev or linuxcnc-uspace-dev
The following user(s) said Thank You: masterjuggler
- CNC_ANDI
- Thank you received: 31
24 Jan 2023 16:58 - 24 Jan 2023 17:00 #262823
by CNC_ANDI
Replied by CNC_ANDI on topic Probe Basic spindle load bar off by a decimal
at
halcompile --install load_conv.comp
i get this error:
i get this error:
cnc@debian:~$ halcompile --install load_conv.comp
File "/usr/bin/halcompile", line 1556, in <module>
main()
File "/usr/bin/halcompile", line 1526, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1366, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 434, in parse
f = open(filename).read()
FileNotFoundError: [Errno 2] No such file or directory: 'load_conv.comp'
where i can find load_conv.comp?For my install i used the joco-nz bullseye installer to install the dev version of probe basic and linuxcnc 2.9
Last edit: 24 Jan 2023 17:00 by CNC_ANDI.
- TurBoss
24 Jan 2023 17:00 #262825
by TurBoss
- CNC_ANDI
24 Jan 2023 17:18 #262827
by CNC_ANDI
thanks.
percent = round(amps/0.12);
is for 12A at 100 or 150%?
cnc@debian:~/linuxcnc/configs/CNC-ANDI$ sudo halcompile --install load_conv.comp[sudo] password for cnc:
Compiling realtime load_conv.c
Linking load_conv.so
cp load_conv.so /usr/lib/linuxcnc/modules/percent = round(amps/0.12);
Moderators: KCJ, Lcvette
Time to create page: 0.813 seconds
