Functioning Fadal conversion from Gmoccapy to Probe Basic
3 years 10 months ago #259627 by tommylight
@LCVette,
There is a deleted post in this topic made by you, did you delete it?
Need to know if we should restore it or permanently delete.
Thank you.
The following user(s) said Thank You: Lcvette
3 years 10 months ago #259636 by COlger81
Doesn't the widget just pull from the CAROUSEL component after it is referenced? Shouldn't the turret widget just track carousel.N.homing and carousel.N.homed?
3 years 10 months ago #259638 by COlger81
When you say copy that over, do you mean into the carousel.comp file?
3 years 10 months ago - 3 years 10 months ago #259646 by Lcvette
@tommylight you can permanently delete, hit delete while trying to hit edit, so just started the post over.. /o\
Last edit: 3 years 10 months ago by Lcvette.
3 years 10 months ago #259649 by Lcvette
i have not dug into the carousel comp, but the dynatc items in straight macro driven atc is just in the Mxx macros in sections that are commanding carousel movement and that is how the widget is synchronized to the machine movement commands  if you want to post up your atc macros we could look at them.  wouldn't be a bad thing to add them to a fadal conversion file in probe basic.
3 years 10 months ago #259653 by COlger81
The carousel component is really nice. I don't see too many ATC setups if any that will not work with carousel component. What element do i need to tie my "carousel.0.homed" to? You should consider including pins to allow user to tie the carousel component pins to your widget turret.
Also, Gmoccapy has "analog-enable" pins to tie to physical overrides. It makes override setup very easy. Example below
setp     gmoccapy.rapid.rapid-override.analog-enable 1
net      rapid-override-gmoc      gmoccapy.rapid.rapid-override.direct-value    <=    rapid.override-output
Moderators: KCJ, Lcvette
Time to create page: 0.318 seconds
