- User Interfaces
- Other User Interfaces
- QtPyVCP
- Developer Install for Probe Basic Py3 (For UI Development Only)
- Lcvette
- Thank you received: 784
09 Mar 2023 23:11 #266260
by Lcvette
Developer Install for Probe Basic Py3 (For UI Development Only) was created by Lcvette
Requirements:
Debian 12 Bookworm (or later)
Linuxcnc 2.9 (or Later)
This is the Development installation for QtPyVCP and Probe Basic:
It is not recommended to run a machine with this installation as it is a run in place inside a virtual environment (venv) as python calls it. It may run just fine but i have not tested it so have no idea if the venv will introduce any odd latency issues. This is the new norm for programs installed with pip. This installation is very simple to install and will set you up with the development tools needed to work on probe basic and contribute through your favorite tool for handing your repositories.
The installation instructions are found here:
github.com/Lcvette/qtpyvcp-bookworm-installer
and follow along video here:
The following user(s) said Thank You: TurBoss, tommylight, elovalvo, spumco, CNC_ANDI, nwallace, Unlogic
- Thank you received: 4155
09 Mar 2023 23:47 - 09 Mar 2023 23:47 #266263
Replied by rodw on topic Developer Install for Probe Basic Py3 (For UI Development Only)
Tested and confirmed its working...
Last edit: 09 Mar 2023 23:47 by rodw.
The following user(s) said Thank You: Lcvette
- spumco
- Thank you received: 905
10 Mar 2023 14:24 #266329
by spumco
Replied by spumco on topic Developer Install for Probe Basic Py3 (For UI Development Only)
OMG, that was stupid easy.
Confirmed working on a Win10 Virtualbox VM w/ Bookworm.
- CNC_ANDI
- Thank you received: 31
13 Mar 2023 06:57 - 13 Mar 2023 07:09 #266540
by CNC_ANDI
Replied by CNC_ANDI on topic Developer Install for Probe Basic Py3 (For UI Development Only)
having error
Last edit: 13 Mar 2023 07:09 by CNC_ANDI.
- Lcvette
13 Mar 2023 11:27 #266567
by Lcvette
Replied by Lcvette on topic Developer Install for Probe Basic Py3 (For UI Development Only)
In the development installation, the provided launchers on the desktop must be used.
if you want machine control installation you must use the .deb installation in the sticky thread here:
forum.linuxcnc.org/qtpyvcp/48373-qtpyvcp...llation-files-inside
The following user(s) said Thank You: CNC_ANDI
- CNC_ANDI
13 Mar 2023 11:33 #266569
by CNC_ANDI
i used the luncher on the desktop... but become this error
- Lcvette
13 Mar 2023 11:37 #266570
by Lcvette
is this on deb 12?
- CNC_ANDI
14 Mar 2023 09:03 #266662
by CNC_ANDI
yes using a clean debian bookworm with xfce
- Lcvette
14 Mar 2023 11:17 #266670
by Lcvette
looks like a conflict here:ERR| vtkShaderProgram (0x64906c0): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES
you need a graphics card that support GLSL 1.50 or greater
- CNC_ANDI
14 Mar 2023 12:44 - 14 Mar 2023 13:58 #266679
by CNC_ANDI
ok i will check this... i will put in a pcie graphicscard
edit: Works now fine! Many Thanks you are great!
Last edit: 14 Mar 2023 13:58 by CNC_ANDI.
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.107 seconds
