Developer Install for Probe Basic Py3 (For UI Development Only)
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Moderator
  • Moderator
15 Mar 2023 14:17 #266752 by Lcvette
no worries, glad to have been able to help!
22 Mar 2023 11:54 #267298 by rodw
Tested and confirmed working on Armbian OS and Odroid N2+  (with 6 core ARM CPU)
Long way to go with Armbian yet, but this means this script should also work on the Pi and other CPU's supported by Debian.
Th Odroid PC is shown to the left of the keyboard
The following user(s) said Thank You: tommylight, Lcvette
27 Mar 2024 16:38 #296918 by merongi
One problem to report and one stupid question.
Problem to report
After following up all the procedures, desktop "Probe Basic Mill" icon ended up errors on launching.
Based on debug messages, "probe_basic_postgui.hal" has three problematic lines about manual toolchange. I had to comment these three lines out to make it run. Error message is that port qtpyvcp_manualtoolchange.xxxx are not found.
# ---manual tool change signals---
#net tool-change-request => qtpyvcp_manualtoolchange.change
#net tool-change-confirmed <= qtpyvcp_manualtoolchange.changed
#net tool-number => qtpyvcp_manualtoolchange.number
Stupid question.
I used "Designer for PB Mill" desktop icon to change GUI.
Saved (closed and reopened to check whether it's really changed).
Ran updater.sh (checked probe_basic.ui => probe_basic_ui.py ... ok)
But running "Probe Basic Mill" icon on desktop still shows unmodified GUI.
What am I missing?
28 Mar 2024 21:11 #297038 by spumco
Stupid question.
What am I missing?
Not stupid at all.
Assuming you just started editing the Probe Basic files that were installed on your computer, updater.sh (you can open it with a text pgm and see what it's doing) pulled the most recent files from the Probe Basic repository on GitHub and overwrote your changes.
If you make changes to the UI, you need to decide on a way to keep the changes from getting overwritten.  Some options:
1. Never update once you edit the UI
2. Save the UI file(s) in a different location, and then after updating compare the changes between the two sets of files and work out how to merge the modified vs. new files.
3. Make a fork or branch of Probe Basic on GitHub.  You can then edit your branch.  I think this allows you to review & merge differences easier, but I'm not really competent to walk you through the process.
08 May 2024 22:55 #300165 by Dragonick
I follow the instructions, but at the last point at the very end I get this error. What am I doing wrong ?
Compiling .qrc files in package '.':
  probe_basic_lathe.qrc => probe_basic_lathe_rc.py ... ok
  probe_basic.qrc => probe_basic_rc.py ... ok
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/Designer for PB Lathe.desktop': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/Designer for PB Mill.desktop': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/Probe Basic Mill.desktop': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/Probe Basic Lathe.desktop': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/Probe Basic ATC Mill.desktop': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/Probe Basic ATC Mill Metric.desktop': No such file or directory
sed: can't read /root/Desktop/Designer for PB Lathe.desktop: No such file or directory
sed: can't read /root/Desktop/Designer for PB Mill.desktop: No such file or directory
sed: can't read /root/Desktop/Probe Basic Mill.desktop: No such file or directory
sed: can't read /root/Desktop/Probe Basic Lathe.desktop: No such file or directory
sed: can't read /root/Desktop/Probe Basic ATC Mill.desktop: No such file or directory
sed: can't read /root/Desktop/Probe Basic ATC Mill Metric.desktop: No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/probe_basic_icon.png': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/probe_basic_icon_lathe.png': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/dev_launchers/qtpyvcp2.png': No such file or directory
cp: cannot stat '/home/root/dev/probe_basic/fonts/BebasKai.ttf': No such file or directory
09 May 2024 12:20 #300220 by Dragonick
I tried to install with ProbeBasic installer 0.4.0 run. This error pops up. Is there a solution for this?
09 May 2024 19:34 #300237 by Dragonick
Stupid mistake, everything is clear.
For posterity, the problem occurred while installing debian. The problem was adding the root password during installation.
10 May 2024 03:15 #300279 by rodw
This is OK but you need to add a new user and then add that user to the sudoers group.
Moderators: KCJLcvette
Time to create page: 0.308 seconds
