Probe Basic AttributeError
- Julien
28 Apr 2023 18:27 - 28 Apr 2023 18:33 #270121
by Julien
Probe Basic AttributeError was created by Julien
Hello, I have installed bookworm and probe basic according these guides in this forum:
Py3 -Development Install for Probe Basic and QtPyVCP
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Sadly when I try to start my machine I get the following error message:
See attached .txt
I have already tryed to reinstall QtPyVCP and probe basic but it did not help.
See attached .txt
Last edit: 28 Apr 2023 18:33 by Julien.
- Lcvette
- Thank you received: 783
29 Apr 2023 14:03 #270206
by Lcvette
Replied by Lcvette on topic Probe Basic AttributeError
the development version must be run with the supplied launchers as the activate the require virtual environment, they are scripts. if you want to just use probe basic you need to use the .deb installation method as that performs a system wide install that works like any other user interface.
Moderators: KCJ, Lcvette
Time to create page: 0.109 seconds
