- User Interfaces
- Other User Interfaces
- QtPyVCP
- Linear units are set to mm but ProbeBasic shows coordinates in in
- merongi
- Thank you received: 13
13 May 2023 05:16 #271275
by merongi
Linear units are set to mm but ProbeBasic shows coordinates in in was created by merongi
Hello,
I installed LinuxCNC 2.9 on Debian Bookworm following the method from this forum.
I copied probe_basic sim folder and updated it with ini/hal from StepConf.
Basic movement, homing and spindle controls are working as it should but I'm having two issues.
1. I want to use metric units and put it on .ini but coordinates are still shown in inch form. Anything need to do for this?
2. When I tried to probe, it shows ERRORs that probe move on line 37 exceed joint 2's negative limits.
Any hint where to look?
- merongi
13 May 2023 05:21 #271276
by merongi
Replied by merongi on topic Linear units are set to mm but ProbeBasic shows coordinates in in
While writing this question, I got a hunch that all the parameters for probe I have entered were in mm and I guess ProbeBasic is using inch.
So I updated all parameters in Inch and now probe routine works.
Now only question is how to use metric unit in ProbeBasic?
- Lcvette
- Thank you received: 782
13 May 2023 05:25 #271277
by Lcvette
Replied by Lcvette on topic Linear units are set to mm but ProbeBasic shows coordinates in in
Check the start up line in the ini, it's probably setting G20, change it to G21.
Probing units are just numbers they will follow whatever mode you are in, so if your system is set to metric, then you will get mm movement, if your in inches you will get inches movement.
The following user(s) said Thank You: ben_benson
- merongi
13 May 2023 05:29 #271278
by merongi
Searched forum with metric and found the answer.
There was G20 in INI and updated it to G21 solved the problem.
The following user(s) said Thank You: Lcvette, ben_benson
- Lcvette
13 May 2023 05:35 #271279
by Lcvette
Yup you found it, good work! Enjoy!
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
