- Thank you received: 13
You are on the right track. Sensor config looks good.Thanks Spumco!!
So as i am working with a geneva drive, so if we focus on that.
I will install one homing sensor ( inductive Proximity Sensor )
Secondly , i will install one inductive proximity sensor that will be triggered each time a pocket passes by. So the sensor will be on a fixed location and a screw will be used at the position of each sensor to trigger this sensor. Will this be enough for probe basic to count the pockets and know where is which pocket?
Thirdly i will install the laser sensor to check if a pocket is empty
Fourth i would install an inductive proximity sensor to sense if the lid of the toolchanger is opened and another sensor to confirm if the lid is closed to avoid crash of the spindle and the dustcover of the toolchanger.
