Creating ATC carrousel from scratch (documented with CAD models)
28 Jul 2023 20:45 #276481 by Marcodi
Hello Everyone,
It has been a year or 3 since I needed to change my machine, I've reading on the forum and so it seems linuxCNC has again evolved a lot since then. Congrats and thanks to all developers!!!
I was finally able to buy an ATC spindle and thus I have to rewire and extend my machine. First steps are of course the CAD designs of spindle and carousel, and open source wouldn't be open source if people didn't share their work, so please follow along this thread to find all parametrical cad designs I will draw to build your own carousel. I will upload them as I go along in the design. (Solidworks and .step format)
Of course I will be having some questions of my own, I have looked into the probe basic GUI and that looks awesome. For the moment I thus only have 1 question, how much pockets can the GUI of probe basic handle. I saw in most screenshots a 12 tool carrousel but I would like to build a little bigger. Up to 36 tools. Can probe basic screen show this graphically or is there a certain max of toolholders for the graphics screen? I looked to the documentation and forum but couldn't find an answer to this. Hopefully someone knows this?.
While reading through the forum past days, I think I could conclude that a stepper/Geneva drive would be best suited to keep the implementation as simple as possible. Am I correct in my assumption? As this will determine the type of design I will.make and share for others
After the designs i will step by step update how I build the entire ATC, so anybody else in need can follow this as a tutorial as I didn't find any complete tutorial to build and ATC with cad designs on the forum. I will try to do my best and try to keep a standard as high as the pro's around here.
Happy milling everyone!!!!!!
28 Jul 2023 22:25 #276492 by tommylight
We had quite some back and forths a while back regarding ATC, DIY and 3D printing, so have a look might find something interesting ... or something worth a laugh or two. :)
forum.linuxcnc.org/38-general-linuxcnc-q...-debug-phase?start=0
The following user(s) said Thank You: Marcodi
28 Jul 2023 22:53 #276496 by tommylight
Found the other topic also, this one has some actual designs and attached files for them
forum.linuxcnc.org/qtpyvcp/48649-probe-b...-toolchanger?start=0
31 Jul 2023 23:18 #276671 by Marcodi
Thanks a lot for these 2 threads, I have read through them but still couldn't find the answers to the maximum amount of toolholders the Probe Basic GUI can display. Could anyone using Probe Basic have a look once to see in the setup what the maximum amount of pockets is that Probe Basic can display? Thanks
01 Aug 2023 00:42 #276672 by tommylight
I just did a search using google and coercing it to show results only from this website/forum, like this
Probe Basic max number of tools site:linuxcnc.org
and this is the first result it returned
forum.linuxcnc.org/qtpyvcp/39621-solved-...number-999-wont-work
search google for "google hacking" there are a lot of such tips to narrow searches, like
"probe basic" site:linuxcnc.org
will return results from this web/forum only if they contain the exact phrase "probe basic"
01 Aug 2023 02:37 #276676 by rodw
Not sure there is a limit. Its just that you might need to create another graphic or two. I vaguely remember some discussion about this.
I would also look at qt-dragon which gives you a similar feature set and very good documentation in the V2.9 docs
01 Aug 2023 11:44 #276692 by Marcodi
I have gotten the answer through GitHub. As for now the following is supported:
[ATC]# Carousel image available for 8, 10, 12, 14, 16, 18, 20, 21, 24POCKETS = 12STEP_TIME = 500
So I will design accordingly. Thanks all for the help so far.
01 Aug 2023 18:03 #276717 by spumco
Tommy & Rod have covered the bases, but I'll add a couple thoughts.
You can, of course, use any mechanism you'd like.  But the standard macros/subroutines that come with Probe Basic are designed around:
Geneva-drive carousel
On/off rotational motor control ('dumb' DC or AC motor) using two relays or similar
Pneumatic actuator/slide for carousel in/out
basic on/off power drawbar
1 sensor with a per-pocket trigger
1 sensor with a once-per-rev trigger
All the logic & sequencing you need are in the built-in macros.  Of course, multiple values inside the subroutines and LCNC variable table will need adjusting depending on your IO numbers, pocket count, and similar.
If you would like to use a different mechanism, there are a couple of working examples on the forum.  GuiHue has posted an excellent configuration using a step & direction motor with a reducer for a router-type machine.
02 Aug 2023 06:17 #276760 by pawel77
You can buy an existing one and make reverse engineering. if you need your own. For 400€ you can have a one like this,  allegrolokalnie.pl/oferta/automatyczny-m...i-cnc-hurco-bmc40-fv
I am not the seller.
But align everything mechanically to your mill is a lot o work. and time, better to buy an old milling machine a align everything electrillay only :)
cheers
04 Aug 2023 21:56 #276935 by Marcodi
Thanks for the ideas, but in this case i want to make it myself, nothing better than made-at-home, otherwise, where is all the fun :)
I will update this post until the entire carrousel is designed, but in the meantime, i will share the intermediate files. So as of now, i have designed the base shaft and the base disc. This is already quite parametrical, except for the shaft, that has to be sturdy enough to support no matter what toolchanger. I want to keep the cost of production as low as possible, so for the shaft we need a 60mm steel rod that will have to be machined and the discs are made up of 10mm aluminium plate ( everyone can machine this themselves) and a standard 150mm x 5mm aluminium tube ( which can be bought.
Design in solidworks 2020!
File Name: Toolchanger.rar
File Size:971 KB
Moderators: KCJ, Lcvette
Time to create page: 0.150 seconds
