Trouble getting Probe Screen To Work
  • Mayberry Customs
  • Senior Member
  • Senior Member
07 Jul 2023 04:21 #274925 by Mayberry Customs
Trouble getting Probe Screen To Work was created by Mayberry Customs
Hi, I have done a new install of Debian 12 bookworm and followed all the instructions that I’m aware of to install probe basic. I can open the sim version of probe basic just fine. I have created a new configuration and done the necessary file movements, ini changes, and Hal changes that are explained in the sticky in this section of the forum. I still get an immediate error log when trying to start probe basic. The configuration is works as expected in Axis. I have attached a picture of the error. It always errors out at “can’t execute DISPLAY program: probe_basic …Would greatly appreciate any and all help!
07 Jul 2023 05:35 #274927 by Lcvette
Replied by Lcvette on topic Trouble getting Probe Screen To Work
which installation did you do? and i don't see any attachment. please post it again :D
  • Mayberry Customs
  • Senior Member
  • Senior Member
07 Jul 2023 11:40 #274936 by Mayberry Customs
Replied by Mayberry Customs on topic Trouble getting Probe Screen To Work
I am realizing now that I installed the development version without realizing it, which is obviously a problem…can I simply follow the steps for the “user” install or are there steps I need to take to get rid of the files from the development version first?
07 Jul 2023 17:06 #274941 by Lcvette
just delete the icons on the desktop and delete the dev folder in the main directory, since the development version is run in a virtual environment it is not installed in the main system.
then proceed with the apt install method in the main probe basic instructions page link.
should be good to go!
  • Mayberry Customs
  • Senior Member
  • Senior Member
07 Jul 2023 17:08 #274942 by Mayberry Customs
Ok great, thanks a lot!
The following user(s) said Thank You: Lcvette
Moderators: KCJ, Lcvette
Time to create page: 0.116 seconds
