I am an idiot...3D Probe with Probe Basic
3 years 2 months ago #277869 by msrdiesel
So I am trying to probe a PCB, which is 1.5mm thick, but the probe drops down too far. The EXTRA PROBE DEPTH should be able to accept a negative number to compensate for this.
What do I change to set the depth the probe drops below the Z height. I could lay something of a known thickness on top of the PCB but that defeats the purpose.
This really needs to be implemented in the UI, maybe I am not seeing something???
3 years 2 months ago #277870 by Lcvette
It uses the probe tip diameter for the base depth which is standard, if you need less you would typically use a stylus ball suited to the requirement. But I think that idea to allow negative number in Calc is worthwhile to investigate.
I'm away from dev, but in the interim, you can use the straight probe functions which don't require z to move at all during probing, or like you mentioned, use a shim.
The following user(s) said Thank You: msrdiesel
3 years 2 months ago #277874 by msrdiesel
Mine is already quite puny at 0.078". If I knew where to change the code to let it accept a negative number, I would make the change myself. Is the input text box set to only allow for positive numbers, because it removes the leading negative. If that were the case it may be an easy fix.
3 years 2 months ago #277879 by Lcvette
Sorry was trying to edit this post and hit delete on accident.
Depending how you installed probe basic you may or may not have access to the probe_basic.yml file.  If you do,  you can do the following:
Change the min value shown in the file below to:
min_value: -100
3 years 2 months ago - 3 years 2 months ago #277905 by Lcvette
I was able to test the change recommended above and confirmed it does now accept negative entries in the extra probe depth user entry.  the change has been pushed to the latest version, for 2.8.4 you will need to manually update it in a dev installation.
Last edit: 3 years 2 months ago by Lcvette.
3 years 2 months ago - 3 years 2 months ago #277907 by msrdiesel
I will try to make a video this week and post the link, I will go through all I know about probing which isn't much. Maybe it will be a help to someone.
Thank you for your help, much appreciated.
Last edit: 3 years 2 months ago by msrdiesel.
Moderators: KCJ, Lcvette
Time to create page: 0.124 seconds
