y-axis throws error during homing; same config works well in axis
16 Aug 2023 21:36 #278200 by routerman22
So i recently converted my hal and INI from Axis to probe basic.
But I get a weird issue where I get a "cannot unhome when homing joint 1" error. during the homing stage of the Y axis.
The same config works well in the axis GUI. The y axis tandem moves (in my case to Y max) , hits limit switch and immediately throws this error.
I have attached the HAL and INI of both screens. the AXIS one works well and as expected. the PB (probe basic one) , throws the error mentioned above. I have compared them over and over again but I'm unable to figure out what it is.
Anybody experienced this before?
17 Aug 2023 13:20 #278262 by TurBoss
hello,
The only difference i saw that can affect that could be this
looks like "min-hom-y" doesn't exist on the hal file other than this 2 lines
The following user(s) said Thank You: routerman22
17 Aug 2023 17:49 #278285 by routerman22
I will try it.
I tried changing the home and home offset positions (840 to creat more space vs lim sw) and that did not help. Not a home ifnore lim = yes flag.
17 Aug 2023 18:01 #278289 by routerman22
I tried this + i had to invert my home search direction vs what i have in axis (went the opposite way????) And now it successfully homed. Very confusing.
Thanks for the help!
Moderators: KCJ, Lcvette
Time to create page: 0.586 seconds
