Probe Basic - Recent Rack ATC Implementation Example?
- udoS
- Thank you received: 25
26 Nov 2023 14:25 #286552
by udoS
Replied by udoS on topic Probe Basic - Recent Rack ATC Implementation Example?
That's not a rack I guess
So here you have it; Probe-Basic ..
ATC Rack 5 Positions ToolLengthSensor;
L.G. udoS
L.G. udoS
- Lcvette
- Thank you received: 783
29 Nov 2023 15:14 #286793
by Lcvette
Replied by Lcvette on topic Probe Basic - Recent Rack ATC Implementation Example?
looking good! are you still running ethercat? how are you liking it?
- SkyMoCo
- Thank you received: 4
29 Nov 2023 18:44 #286807
by SkyMoCo
Replied by SkyMoCo on topic Probe Basic - Recent Rack ATC Implementation Example?
Nice video, have you published your HowTo and configuration?
- udoS
30 Nov 2023 07:26 #286849
by udoS
I do not use igH, I use industrial plc from LogicLab and I love it. Best thing there is.looking good! are you still running ethercat? how are you liking it?
- scotth
- Thank you received: 62
30 Nov 2023 16:22 #286883
by scotth
Replied by scotth on topic Probe Basic - Recent Rack ATC Implementation Example?
What is the model number for industrial plc from LogicLab.
Looking at Ethercat.
- udoS
01 Dec 2023 08:19 - 01 Dec 2023 08:54 #286945
by udoS
Axel Automation Suite 4.0.3
LLExec installer for Ubuntu x64 2.22.01
How-to for LLExec Ubuntu x64
L.G. udoS
Last edit: 01 Dec 2023 08:54 by udoS.
- udoS
01 Dec 2023 09:01 #286949
by udoS
@scotth
to be clear: this is a software-plc running on the same pc like the LinuxCNC;
So there is no "Model Number "
You need a PC with e.g. Linux PREEMPT Debian11;
Then installing LinuxCNC;
Then installing Runtime LLExec installer for Ubuntu x64 2.22.01
That's your basic setup;
L.G. udoS
L.G. udoS
- Lcvette
04 Dec 2023 06:34 #287169
by Lcvette
what is that squeaky noise on your axis motion? sounds like misaligned motor screw with squeaky lovejoy type couplers maybe? is that setup for ethercat documents somewhere already?
- udoS
08 Dec 2023 09:15 #287506
by udoS
So here is what it is now;
cnc-NexT© LinuxCNC & LogicLab EtherCAT XML
HMI Probe-Basic or QtDragon
Standard Fanless PC with intel i5 and 2xi211 NIC and HDMI/DP 8Gb RAM and 256Gb SSD
5 Pocket Rack-Type ATC with Tool Length Sensor
JMC iHSV-57-EC-xx-xx EtherCAT Servo Drives
Jianken ATC Spindel 1.5KW 32K rpm
VFD Omron MX2 2.2KW with EtherCAT interface
Beckhoff EK1100 with 2 x EL1859 Dig I/O
Hope you enjoy. udoS
Moderators: KCJ, Lcvette
Time to create page: 0.150 seconds
