Probe_Basic ToolTouchOff
2 years 10 months ago #287132 by dpslwk
Replied by dpslwk on topic Probe_Basic ToolTouchOff
o<program_coolant> call [300] [50] [100] [5] [2] [118.2432] [0] [0] [0] [#5410]
that should have been
o< tool_touch_off> call [300] [50] [100] [5] [2] [118.2432] [0] [0] [0] [#5410]
The following user(s) said Thank You: CNC_ANDI
2 years 10 months ago #287211 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic ToolTouchOff
I don't need auto tool measurement.
Ok got it work with the original tool_touch_off.ngc
I am only added 2 things. From the old tool_touch_off by ToolTall
1. Offset for big tools
my toolsetterplate only have 14mm so i can't measure tools than bigger like 14mm
This mod makes a auto offset of 50% or what you want (you can set it by yourself) in the direction you want for tools
Where bigger than 14mm or what you want (you can set it by yourself)
2. Other measure point for 3D Probe with Z offset to the normal toolsetter
This mod will make a another measure point for my 3D Probe and includes a Z offset to the normal toolsetter.
The toolnumber, coordinates, offset must set by yourself.
I will include the ngc tomorrow.
2 years 10 months ago #287368 by CNC_ANDI
so here is my actually working tool_touch_off.ngc
2 years 10 months ago #287460 by Lcvette
Replied by Lcvette on topic Probe_Basic ToolTouchOff
Probe basic has diameter offset built in Already,  you need to check the button for it on the offsets page.  This moves the tool to its edge centered over the tool setters center. This is useful for larger diameter tools such as fly cutters and facemills.
2 years 10 months ago #287464 by CNC_ANDI
ok thx. but with my mod i can not forget it. this mod makes the offset by itself. ^^
2 years 10 months ago #287466 by Lcvette
The checked setting is stored until unchecked, remains check through restarts also
Moderators: KCJ, Lcvette
Time to create page: 0.073 seconds
