Can qtpyvcp be enabled when Latency-test exceeds its maximum value?
2 years 9 months ago #291578 by szl
The following message appears when running qtpyvcp, is there a way to get it fixed?
Debug file information:
Note: Using POSIX realtime
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
  File "/usr/bin/qtpyvcp", line 8, in <module>
    sys.exit(main())
  File "/home/szl/.local/lib/python3.11/site-packages/qtpyvcp/app/__init__.py", line 73, in main
    opts = parse_opts(__doc__)
  File "/home/szl/.local/lib/python3.11/site-packages/qtpyvcp/utilities/opt_parser.py", line 104, in parse_opts
    opts = DotDict({arg.strip('-<>').replace('-', '_') : convType(value) for arg, value in raw_args.items()})
  File "/home/szl/.local/lib/python3.11/site-packages/qtpyvcp/utilities/opt_parser.py", line 104, in <dictcomp>
  File "/home/szl/.local/lib/python3.11/site-packages/qtpyvcp/utilities/opt_parser.py", line 65, in convType
    if isinstance(val, basestring):
NameError: name 'basestring' is not defined
1925
1968
Stopping realtime threads
Unloading hal components
2 years 9 months ago #291588 by CNC_ANDI
try to set servo period 100000 higher
tune your system to get a better latency
2 years 9 months ago #291600 by tommylight
Are you using a parallel port?
If not, you should remove the line containing BASE_PERIOD.
This and the reply before will not fix the issue you are having, sorry i can not help with it.
The following user(s) said Thank You: Lcvette
2 years 9 months ago #291905 by Lcvette
need alot more information to help answer the question. but this is in most likely scenario an ill formatted configuration setting.  I would styart by going through and looking for any mossing ini parameters related to using the basethread.
linuxcnc.org/docs/stable/html/config/ini...l#sub:ini:sec:emcmot
Moderators: KCJ, Lcvette
Time to create page: 0.053 seconds
