AMD64 cpu only for Probe Basic?
- eMTea
10 Feb 2024 11:29 #292984
by eMTea
AMD64 cpu only for Probe Basic? was created by eMTea
Hi!
Do I understand correctly, that Probe Basic is only compatible with AMD64 based computers?
I have 2 all-in-one touch screen pc's with Intel CPU's :/
- Calysto
- Thank you received: 6
10 Feb 2024 12:50 #292987
by Calysto
Replied by Calysto on topic AMD64 cpu only for Probe Basic?
AMD64 is just the name of a cpu type, like x86 and arm64. AMD64 woll run on Intel 64bit cpu's too.
The following user(s) said Thank You: eMTea
- Unlogic
- Thank you received: 128
10 Feb 2024 12:54 #292988
by Unlogic
Replied by Unlogic on topic AMD64 cpu only for Probe Basic?
AMD64 is the name of the 64-bit x86 cpu instruction set. Essentially all Intel CPU's from the Core 2 Duo (2007-ish) era and forward support it so you should be fine unless you've found some really ancient hardware.
However take note of the graphics requirements for Probe Basic. Some older graphics card don't support the required OpenGL and/or pixel shader versions for Probe Basic.
- eMTea
11 Feb 2024 20:50 #293108
by eMTea
Replied by eMTea on topic AMD64 cpu only for Probe Basic?
Thanks guys! Will check it out!
Moderators: KCJ, Lcvette
