It appears QtDesigner is trying to load the QtPyVCP widgets using a python vers
2 years 8 months ago #294560 by szl
Hello, I have a small questionWhen I execute the editvcp vcp command, an error is displayed:
ERROR: It appears QtDesigner is trying to load the QtPyVCP widgets
using a python version greater than 2.7, this is not supported.
Make sure that you have the correct version of the libpyqt5.so
file in /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/, see the
Installation Trouble Shooting section of the QtPyVCP Documents for more info.
May I ask how to solve this problem?
Thank you!
2 years 7 months ago #294901 by andypugh
To run with Python3 it seems you might need to run the dev version of PyQTVCP.
www.qtpyvcp.com/install/index.html
2 years 7 months ago #294944 by rodw
Seems like you have not installed the latest version of qtpyvcp that is required with later versions of linuxcnc/debian
2 years 7 months ago #295127 by Lcvette
looks like you are trying to run the latest version of qtpytvcp on a older python2 linuxcnc install, they are not compatible.  you need to be on linuxcnc 2.9 or greater.
Moderators: KCJ, Lcvette
Time to create page: 0.058 seconds
