ProbeBasic backplot issue?
2 years 4 months ago #303121 by B.Reilly01
Yes, 3 times.... same result.
2 years 4 months ago #303132 by B.Reilly01
New wrinkle. I went back and homed the system. As soon as it moves the error pops up, but I noticed no WCS was selected. I cannot select one until the system homes, but once I can, the backplotter works and the error doesn't reappear. It looks like I'm back where Unilogic was. Now I just have to figure out what part of my config the system dislikes.
The following user(s) said Thank You: Lcvette
2 years 4 months ago #303143 by Lcvette
Replied by Lcvette on topic ProbeBasic backplot issue?
Do you have a program loading on startup?   Typically we load a program file named blank.ngc, it's located in the probe basic examples file.   Try copying it to your nc files folder and setting it as default program in your ini.   This initializes vtk on startup.
The following user(s) said Thank You: B.Reilly01
2 years 4 months ago - 2 years 4 months ago #303166 by B.Reilly01
I do have a program loading on startup (3D_Chips). Weirdly, I do not have a pd_examples file in my nc folder, yet sim still loads fine referencing blank.ngc.
Last edit: 2 years 4 months ago by B.Reilly01. Reason: Clarification
2 years 4 months ago #303178 by Lcvette
in the file tab with blank.ngc loaded, click edit gcode button then save as while you are in your linuxcnc nc files directory and it should copy it over to the correct directory
2 years 4 months ago #303182 by Lcvette
ah in your start up line in the ini file, make sure to set G54 so the backplotter has a starting point!
[RS274NGC] RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P0.001 G80 G90 G91.1 G92.1 G94 G97 G98 PARAMETER_FILE = sim.var OWORD_NARGS = 1 NO_DOWNCASE_OWORD = 1 SUBROUTINE_PATH = subroutines
Moderators: KCJ, Lcvette
Time to create page: 0.126 seconds
