Probe Basic Help
08 Jul 2024 03:14 #304626 by Lcvette
Replied by Lcvette on topic Probe Basic Help
Probably, I'm not sure how you installed it
The following user(s) said Thank You: Catch22
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Jul 2024 16:17 #304925 by Catch22
Replied by Catch22 on topic Probe Basic Help
I am so frustrated with this,I have installed and reinstalled about 10 times now and it doesnt even show up in the Linuxcnc menu.
i have tried following the youtube videos but they are 2 years old and the installation has changed since then.
Could someone possibly put it in an iso with linuxcnc that would work? I will pay for it, i have spent about 6 hours with no success.
11 Jul 2024 16:31 #304926 by Lcvette
There is really only the way I linked a few posts back for the correct user installation.  Maybe if you provide all of the information regarding your pc, iso used,  version of linuxcnc etc.  But really if you follow the linked instructions verbatim it just works unless you are doing something unique?
kcjengr.github.io/probe_basic/development_quick_start_apt.html
Follow these instructions and it will work.  I do it every few days helping others and it has no issues.
If you have other installation attempts,  you may need to start with a clean Debian install.
We would like to have it packaged with linuxcnc,  but unfortunately it was rejected because of politics.  As time and changes happen we have had to change the installation method.  The current will hopefully be the last time that has to happen.  Message us on the matrix chat for faster assistance,  or join the Facebook probe basic group and join the chat there.
Chris
11 Jul 2024 16:36 #304927 by Lcvette
  • Catch22
  • Elite Member
  • Elite Member
12 Jul 2024 03:27 #304958 by Catch22
Ok so I downloaded the linuxcnc with Debian 12 and installed it. And Linuxcnc worked. Then I was very careful and went thought all the steps and added Probe Basic. Unfortunately it wont work, here is the report file.
File Name: linuxcnc.txt
File Size:40 KB
File Size:40 KB
12 Jul 2024 03:34 #304959 by Lcvette
2024-07-11 23:14:48.409 ( 14.098s) [ 6282A040] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x928bc20): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES /usr/bin/linuxcnc: line 977: 5460 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS 5422 5457 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
As stated at the top of the installation page, check your opengl version
  • Catch22
  • Elite Member
  • Elite Member
12 Jul 2024 12:59 #304989 by Catch22
Yes that's it, openly is only version 2.1 mesa 22.3.6
Can I just upgrade this?
12 Jul 2024 13:28 #304995 by Lcvette
depends on your hardware. is this an older pc? you may be able to grab a cheap video card that uses the later version.
  • Catch22
  • Elite Member
  • Elite Member
12 Jul 2024 16:58 #305010 by Catch22
Ya it is old, it a Dell Optiplex 780
12 Jul 2024 21:07 #305030 by Lcvette
you could try a video card, but i would run a latency test with this kernel to see if the pc is worth investing in before i did that.
Moderators: KCJ, Lcvette
Time to create page: 0.696 seconds
