Probe Basic Help
2 years 3 months ago #304926 by Lcvette
Replied by Lcvette on topic Probe Basic Help
There is really only the way I linked a few posts back for the correct user installation.  Maybe if you provide all of the information regarding your pc, iso used,  version of linuxcnc etc.  But really if you follow the linked instructions verbatim it just works unless you are doing something unique?
kcjengr.github.io/probe_basic/development_quick_start_apt.html
Follow these instructions and it will work.  I do it every few days helping others and it has no issues.
If you have other installation attempts,  you may need to start with a clean Debian install.
We would like to have it packaged with linuxcnc,  but unfortunately it was rejected because of politics.  As time and changes happen we have had to change the installation method.  The current will hopefully be the last time that has to happen.  Message us on the matrix chat for faster assistance,  or join the Facebook probe basic group and join the chat there.
Chris
2 years 3 months ago #304958 by Catch22
Replied by Catch22 on topic Probe Basic Help
Ok so I downloaded the linuxcnc with Debian 12 and installed it. And Linuxcnc worked. Then I was very careful and went thought all the steps and added Probe Basic. Unfortunately it wont work, here is the report file.
File Name: linuxcnc.txt
File Size:40.39 KB
File Size:40.39 KB
2 years 3 months ago #304959 by Lcvette
2024-07-11 23:14:48.409 ( 14.098s) [ 6282A040] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x928bc20): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES /usr/bin/linuxcnc: line 977: 5460 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS 5422 5457 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
As stated at the top of the installation page, check your opengl version
2 years 3 months ago #304989 by Catch22
Yes that's it, openly is only version 2.1 mesa 22.3.6
Can I just upgrade this?
2 years 3 months ago #304995 by Lcvette
depends on your hardware. is this an older pc? you may be able to grab a cheap video card that uses the later version.
Moderators: KCJ, Lcvette
