probe basic dro scales in inces instead mm
  • anfänger
  • anfänger's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Aug 2024 16:50 #306933 by anfänger
I am trying to setup my mill and i have something stage going on.
my dro gives me different values than halui.
When I use the jog function 1mm my mill moves one mm. the dro on hand wheel says 1mm.
the dro of probe basic 0.0394. so 1/25,4 inches
is there a setting for probe basic to switch between imperial and metric units?
Thanks Patrick
05 Aug 2024 03:14 #306959 by spumco
Replied by spumco on topic probe basic dro scales in inces instead mm
I think PB gets the DRO units from INI, but I noticed this:
forum.linuxcnc.org/qtpyvcp/48401-py3-pro...-doc-lcnc-2-9#287437
When I was poking around.  Maybe check your RS274 startup values?
The following user(s) said Thank You: Lcvette
  • anfänger
  • Platinum Member
  • Platinum Member
05 Aug 2024 16:31 #307009 by anfänger
Replied by anfänger on topic probe basic dro scales in inces instead mm
yes it was in the RS274 values. didn't think about checking them.
Many thanks
The following user(s) said Thank You: Lcvette, spumco
Moderators: KCJ, Lcvette
Time to create page: 0.283 seconds
