Probe Basic with 3d Probe and Manual Toolv change
2 years 2 months ago #307681 by pastera
Seig X1 micro mill moved from an old computer with a parallel port breakout to a Mesa 7i96 board
Had a tool touch off sensor installed from the old setup - linked to probe.in
Installed the scripts to have m6 do a manual change with tool probe - currently doesn't update work offset on an M6 rpobe
Added a 3d touch probe for work probing using or2 to link to the probe.in signal
Both the probe and tool length sensor activate a probe event when activated.
Using the "touch off tool" option in Probe basic correctly sets the tool length and I can get the correct offsets by loading the probe, touching off, probing the work piece and then loading the tool and touching off (tool length updates in tool table)
But using a tXX M6 will load the tool, touch off but it doesn't update the tool table of work offset.
Is there a tutorial on modifying the tool-change.ncg script to update the tool table the same way that tool_touch_off.ncg?
Or, even better, has anyone done a similar setup that I can duplicate?
I included my hal and ini files for reference
Aaron
2 years 2 months ago #307796 by Sneaky
Have you had any luck solving this? I'm in a similar situation.
2 years 2 months ago #307871 by COFHAL
2 years 2 months ago #307873 by Lcvette
What version are you using? Are you on the latest development version of probe basic?
Moderators: KCJ, Lcvette
