Going from Linuxcnc 2.8.0 to 2.9.3 Using Pncconfig?
- Catch22
- Thank you received: 17
17 Aug 2024 00:40 #307978
by Catch22
Going from Linuxcnc 2.8.0 to 2.9.3 Using Pncconfig? was created by Catch22
Hello Everyone,
I finally got Probe Basic on my new computer, it's a Dell OptiPlex 5040 and everything installed nicely.
My question is can I take my milling machine configuration and use Pncconfig to update it since my original configuration is from version 2.8.0 and make it work with version 2.9.3, I have tried playing around with Pncconfig and it doesn't seem to want to load my original configuration files...
- Thank you received: 7488
17 Aug 2024 00:59 #307981
Replied by tommylight on topic Going from Linuxcnc 2.8.0 to 2.9.3 Using Pncconfig?
Open the folder in any file explorer, right click on the ini file, click on "open with" then in the new window click on "use custom command" and type in linuxcnc and press enter.
Although that might not work as there are way to many things changed in Probe Basic.
The following user(s) said Thank You: Catch22
- Lcvette
- Thank you received: 784
17 Aug 2024 01:02 #307982
by Lcvette
Replied by Lcvette on topic Going from Linuxcnc 2.8.0 to 2.9.3 Using Pncconfig?
The hal shouldn't really change much and the ini and other files can be compared to the probe basic sim config files. Just update the new sections and files. Should only take a few minutes.
The following user(s) said Thank You: tommylight, Catch22
Moderators: KCJ, Lcvette
Time to create page: 0.071 seconds
