- Thank you received: 10
Post GUI HAL not loading and "Bad character '[' used" error on E-Stop
- nwallace
- Topic Author
2 years 2 months ago #308249
by nwallace
Post GUI HAL not loading and "Bad character '[' used" error on E-Stop was created by nwallace
I am having an issue with a machine using probe basic where the post gui hal files are not loading. Looking at the console output when running linuxcnc from the terminal does not show an obvious error to me. It just gets to the line where it is trying to load the first post gui hal file and stops. I have tried removing any customizations but it has no effect. Attached are my hal and ini files.
Another possibly related issue I am having is that if I ever use the e-stop, I get 2 "Bad character '[' used" errors. The error shown in the terminal is "emc/task/emctask.cc 68: interp_error: Bad character '[' used" and it happens even if I have no file loaded.
Has anyone encountered either of these problems? I am at a loss of where to look next on either and would appreciate any help.
- Thank you received: 1863
2 years 2 months ago #308270
Replied by Aciera on topic Post GUI HAL not loading and "Bad character '[' used" error on E-Stop
You've got a lot going on there.
Only thing I see are these MDI_COMMANDS that will cause syntax errors due to comma instead of semicolon but I have no idea if those are actually used anywhere.:
If you run this in MDI do you also get the error about the Bad character '[':
MDI_COMMAND = o<sweep_4x8> call,Sweep\n4x8
#MDI_COMMAND = o<measure_tool> call,Measure\nCurrent\nTool
MDI_COMMAND = G53 G0 Z0;G53 G0 X63 Y5,Go To\nMTC Location
MDI_COMMAND = M64 P7,Open Tool\nMagazine
MDI_COMMAND = M65 P7,Close Tool\nMagazine
(abort, aborting)
The following user(s) said Thank You: nwallace
2 years 2 months ago #308278
Another thing that comes to mind is that only one POSTGUI_HALFILE entry is allowed (unless that has changed):
So if you wanted to load more than one postgui_hal file you would have to create a single (eg 'postgui_call_list.hal') file like this:
Then you would replace the three POSTGUI_HALFILE entries with this single line:
Maybe that helps
POSTGUI_HALFILE = custom_postgui.hal
POSTGUI_HALFILE = vc-postgui.hal
POSTGUI_HALFILE = probe_basic_postgui.hal
# These files are loaded post GUI, in the order they appear
source custom_postgui.hal
source vc-postgui.hal
source probe_basic_postgui.hal
POSTGUI_HALFILE = postgui_call_list.hal
Maybe that helps
- nwallace
- Topic Author
2 years 2 months ago #308317
by nwallace
Replied by nwallace on topic Post GUI HAL not loading and "Bad character '[' used" error on E-Stop
Thank you very much for the help! I feel a bit lame for not realizing that you could only have one postgui_halfile. That has solved that issue.
As for the bad character issue, yes (abort, aborting) does trigger that error but only once instead of twice like an e-stop would.
2 years 2 months ago - 2 years 2 months ago #308324
Not sure if you can have a mix of G- and M-commands like that for an 'ON_ABORT_COMMAND' so try commenting out this line in your ini and see if the error still occurs:
If that fixes it then you may want to use a subroutine call instead. Something like this:
and create a subroutine 'on_abort.ngc' with all the command you want to run on abort
ON_ABORT_COMMAND = G54 G17 G90 G94 M48 G40 M5 G80 M9
ON_ABORT_COMMAND = o<on_abort> call
o<on_abort> sub
;Your Gcodes
;Your Mcodes
o<on_abort> endsub
M2
Last edit: 2 years 2 months ago by Aciera.
- nwallace
- Topic Author
2 years 2 months ago - 2 years 2 months ago #308325
by nwallace
You were correct about the 'ON_ABORT_COMMAND' not working with all those commands. I will go the subroutine route.
I realized I forgot to comment on the MDI_COMMANDS section. Those are formatted that way to show up as buttons in the UI. Everything after the comma is treated as the button text. I just used an example bit of code from the pull request on github to set it up. github.com/kcjengr/probe_basic/pull/84
That example code uses the INI format from QTDragon.
Last edit: 2 years 2 months ago by nwallace.
- nwallace
- Topic Author
2 years 2 months ago #309511
by nwallace
turns out that a traditional sub call does not work in the ON_ABORT_COMMAND option either. It appears that it strips out the <> characters. It errors on a e-stop saying it can't find a subroutine called "Oon_abort". I think I will have to go the custom M code route instead.
2 years 2 months ago #309520
Certainly works for me:
github.com/Sigma1912/LinuxCNC_Demo_Confi...ort_no_twp_reset.ngc
with this in the [RS247NGC] section of the ini:
ON_ABORT_COMMAND = o <on_abort_no_twp_reset> call
- nwallace
- Topic Author
2 years 1 month ago #309874
by nwallace
Turns out the issue was no M2 or M30 at the end of the file. I was just using the % markers at the beginning and end which is the wrong way to do that.
Moderators: KCJ, Lcvette
Time to create page: 0.061 seconds
