- User Interfaces
- Other User Interfaces
- QtPyVCP
- probe basic problem with manual tool change and 3d touch probe
- Ismacr63
- Thank you received: 11
23 Aug 2024 22:05 #308500
by Ismacr63
probe basic problem with manual tool change and 3d touch probe was created by Ismacr63
Hello. I'm using probe basic on a parallel port milling machine.
On the one hand I have a problem with changing tools. I use the buttons on the interface but they don't do anything. If I enter the commands via MDI they change correctly.
I also have a problem with the 3D touch probe, basically it doesn't do anything when I try to calibrate it or do anything. In probe basic it shows true and false when I activate it by hand.
I'm attaching my configuration files in case it's of any use.
- atomicmill
- Thank you received: 6
23 Aug 2024 23:26 #308502
by atomicmill
Replied by atomicmill on topic probe basic problem with manual tool change and 3d touch probe
I think you may be missing the subroutines folder from your machine's config directory. Many UI buttons are linked to such subroutines.
The following user(s) said Thank You: Ismacr63
- Ismacr63
24 Aug 2024 13:44 #308531
by Ismacr63
Replied by Ismacr63 on topic probe basic problem with manual tool change and 3d touch probe
The subroutines folder is in place, but your message made me think that possibly the path in the ini file contains some error.
After checking, I saw that I missed 2 errors in the file path. Now it works fine.
Let's see what the next problem is...
Thank you.
Thank you.
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.261 seconds
