probe basic - toolpath/file preview loading error
1 year 11 months ago #314292 by spumco
The re-numbering workaround seems ok for now.
No way I'm going to risk 3 weeks of linux/LCNC installation misery only to go through it a seconds time for 2.10, 'cause that what always happens whenever I try to install it.image missing /media/kunena/emoticons/smile.png
1 year 11 months ago #314296 by Lcvette
Won't last, it's a tool table index issue. It will start again randomly. Be careful since you're using atc as it may or may not cause an issue.
just as an aside, I uninstalled and reinstalled using the deb method with no issues whatsoever. Took about 15 minutes total to download and do everything. At the least I might try a second SSD and have a 2.9.3 version ready to go just in case, cheap insurance if you're using for business. Also, it may be wise to remain on the lockdown version until they release 2.10 as lockdown. Will avoid these hiccups in future.
1 year 11 months ago - 1 year 11 months ago #314306 by Aciera
You can also patch 'interpret.py' manually:
github.com/LinuxCNC/linuxcnc/pull/3176/files
Last edit: 1 year 11 months ago by Aciera.
The following user(s) said Thank You: Lcvette, spumco, RogEnk
1 year 9 months ago #318178 by spumco
Ive circled back to this after getting annoyed with renumbering my tools for every program.
I've updated to 2.10 since the last time.  (LINUXCNC - 2.10.0-pre0-3745-g8102217123)
I renamed interpret.py and grabbed the latest version from GH (with the 'fix') and put it in the same folder.
Unfortunately, I'm still getting the same error.  Same thing - any tool number >199 causes the error.  Changing the tool(s) to a lower number makes the error go away.
Is there something else I should do to patch, or maybe the patch isn't working?
1 year 9 months ago #318215 by Lcvette
2.9.3 works rock solid
1 year 9 months ago #318237 by spumco
I also switched to PB develop vers... any reason I can't just switch LCNC from 2.10 to 2.9.3?
Moderators: KCJ, Lcvette
Time to create page: 0.070 seconds
