Probe Basic machines won't update after modify in "Designer for PB"
2 years 2 weeks ago #312258 by burnie
Hi, I just installed Probe Basic and qtpyvcp development by following the guide in Probe Basic documentation "Probe Basic Development Installation" on LinuxCNC 2.9.3, Debian 12 Bookworm PREEMPT-RT ISO. I tried making changes like changing the text on buttons and the text on the status page, but after I saved the change by going to "File" and "Save" and launching LinuxCNC with the desktop launcher icons, it did not display the changes I made in QT Designer. I have tried all of the mill desktop launcher icons and made the same changes to the lathe UI with the same result.
And one more thing, can someone please point me to a guide on how to use the modified Probe Basic with normal Linux CNC (creating a .deb)? The instruction is not up on the documentation page yet. Thank you.
2 years 2 weeks ago #312276 by Lcvette
are you using the designer launchers on the desktop to start qtdesigner? this is necessary for the venv.
one of the users that builds his own debs posted this in the group chat.
TAG="0.5.4-128" KMBUILD=6 echo Building $TAG dch --create --distribution stable --package probe-basic --newversion $TAG.stable+km+$KMBUILD KM Build dpkg-buildpackage -b -uc
2 years 2 weeks ago #312277 by Lcvette
also be aware that any changes made will be overwritten if you decide t update down the road with a newer release of probe basic. it may be wise to use the user tabs instead and remain on the stock version if you want ease and simplicity down the road.
we will be implementing some changes that allow certain buttons to be changed via user settings to better fit with routers, such as the flood and mist buttons will be interchangable with vaccum and dustcollector or similar etc.
2 years 2 weeks ago #312327 by burnie
Yes, I use the launchers on the desktop, "Designer for PB Mill" and "Designer for PB Lathe", then launch LinuxCNC with "Probe Basic Mill" and "Probe Basic Lathe" launchers on the desktop.
2 years 2 weeks ago #312328 by Lcvette
I just installed a new dev build from the Doc scripts and it is updating on save as expected. I would check your build, did you change the name when saving?
The following user(s) said Thank You: burnie
2 years 2 weeks ago #312331 by burnie
I clicked on file and save or I hit ctrl+s on the keyboard. If I use "Save As..." it shows that the name it is saving to is probe_basic.ui is this the correct name?
Moderators: KCJ, Lcvette
Time to create page: 0.103 seconds
