- User Interfaces
- Other User Interfaces
- QtPyVCP
- Russian machine tool company that uses LinuxCNC with Probe Basic
- MennilTossFlykune
- Thank you received: 30
24 Oct 2024 10:42 - 24 Oct 2024 10:44 #313049
by MennilTossFlykune
Russian machine tool company that uses LinuxCNC with Probe Basic was created by MennilTossFlykune
Last edit: 24 Oct 2024 10:44 by MennilTossFlykune.
- Unlogic
- Thank you received: 128
24 Oct 2024 11:01 #313051
by Unlogic
Replied by Unlogic on topic Russian machine tool company that uses LinuxCNC with Probe Basic
Interesting, I wonder if they contribute anything back to the community.
- Thank you received: 2176
24 Oct 2024 11:48 #313058
Replied by Aciera on topic Russian machine tool company that uses LinuxCNC with Probe Basic
Mind you there is a fair number of companies and individuals (even some that frequently ask for help on this forum) that make a living using LinuxCNC without giving anything back to the community. Just recently I came across a company in the US that sells Linuxcnc 2.6 (!) installed on a mediocre PC for 1200$.
- hairy
24 Oct 2024 16:02 #313103
by hairy
Replied by hairy on topic Russian machine tool company that uses LinuxCNC with Probe Basic
Tormach's PathPilot CNC controller software is built on top of LinuxCNC.
24 Oct 2024 16:47 #313108
Yes and Tormach did actually contribute to the Linuxcnc source code some years ago.
- Lcvette
- Thank you received: 782
24 Oct 2024 16:57 #313110
by Lcvette
Replied by Lcvette on topic Russian machine tool company that uses LinuxCNC with Probe Basic
craziness..lol
- Thank you received: 7478
24 Oct 2024 17:26 #313116
A big china company that manufactures automation stuff like robotic paletizers use modified LinuxCNC with a simple GUI for a small touchscreen. I dived into the inner workings and sure there where the hal and the ini and examples, all from probably 5-7 years ago. Had very limited time so could not get more info.
Replied by tommylight on topic Russian machine tool company that uses LinuxCNC with Probe Basic
Tormach also used Mesa boards for everything, they still do but i think they started making copies of them in some china factory, has to be confirmed though.Tormach's PathPilot CNC controller software is built on top of LinuxCNC.
The following user(s) said Thank You: hairy
- spumco
- Thank you received: 905
24 Oct 2024 22:46 #313164
by spumco
Replied by spumco on topic Russian machine tool company that uses LinuxCNC with Probe Basic
And there's this one:
www.apsx.com/apsx-nano-cnc-swiss-lathe
Nowhere do they explicitly mention LCNC. It runs on "ASPX CNC software."
And yet...
All the g-codes, M-codes, etc. are identical. Post processor is minor edit of the LCNC post.
Not sus at all.
And yet...
Not sus at all.
24 Oct 2024 23:05 #313167
From their PDF:
And lower on that document, at the "plot tab" is Gremlin (the LinuxCNC visualization screen, not the small monsters from the movie
Last page, board with parallel port, oh yes!
Still the price is not astronomical.
To set the speed of the spindle 0 to 1000 RPM, use M3 S1000 $0 (CW 1000RPM
for the main spindle) and to turn it off use M5 $0.
To set the speed of the spindle 1 to 10000 RPM, use M3 S10000 $1 (CW only) and
to turn it off use M5 $1.And lower on that document, at the "plot tab" is Gremlin (the LinuxCNC visualization screen, not the small monsters from the movie
- spumco
25 Oct 2024 01:26 #313174
by spumco
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 3.777 seconds
