Error getting packages on fresh install on Raspberry Pi 5
1 year 10 months ago #316793 by resmond
I have a list of other 'tasks' that I wound up doing to get my Pi 5/Debian working more like I wanted it to:
1) Figuring out what Raspberry specific apps and config utilities were useful.
2) How to get them accessible from application menu.
If anyone is interested I can post what I have done but I'm new so my list is unlikely to be exhaustive.
I also wonder if that should be a new thread.
1 year 10 months ago #316825 by Cant do this anymore bye all
Remember the Linuxcnc RPi images are not meant to be the same as the Official RPi images. They are not to be used as a "daily driver OS", they are solely implemented to drive a cnc machine, and if you are inclined to do some Linuxcnc development.
menu-config will do most of the same stuff as the RPi utils except for setting up the various hardware related stuff. Enabling the various hardware overlays is done by config.txt, which is really really simple as it is very well documented within the file.
There really should be a "sticky" concerning the configuring of these images, without the need to add any RPi tools. And reminding users that the images are NOT related to other RPi OS's/images and such.
1 year 10 months ago #316920 by resmond
Many of the choices I made during this bumpy configuration journey were driven by reliance on general Linux configuration information sources as I tried to figure out what problem I was actually having at any given moment.
Since I have an inventory of additional uSD & NVME cards I assumed that as my Linux understanding crept up from the near-zero mark I would be starting over at least once reevaluating those choices targeting a less 'chaotic hackers playground' configuration.
Examples of this were installing both GDebi / Synaptic package managers as well as GParted / KDE Partition managers.
I had no idea in either case which would work best or what I would like to choose in the long term, but when I'm in the early learning phase I always know that there will be outright mistakes and sub-optimal choices to say the least.
BTW, I do get your point about the RPi config tools not being necessary for those who know where to go in the Linux config hierarchy to achieve possibly better optimized results but the installation of those tools could always be rolled up in a script as I suspect their inclusion into the XFce application menu for those at their first rodeo.
Now one last actual question:
Even in the situation where someone was going to take a pass on installing the GUI config tools wouldn't it still be valid for all Raspberry builds to have updated APT sources and PGP / keyrings signatures to enable archive.raspberrypi.com (and maybe archive.raspbian.org).
Please correct me if I'm off the mark but wouldn't that be the appropriate 'deb' sources for things other than GUI config tools. Guessing out loud: firmware, eeprom (etc) and possibly purpose built Pi kernels or OS components.
Just wondering. :)
1 year 10 months ago #316928 by rodw
No. The linuxcnc image uses Debian so it uses the Debian repository for all packages.
You can find what is available in APT by checking with the Debian Package Seatch.
packages.debian.org/index
If you want to run PI OS, burn another image from the official  Pi images
None of what you mention is required for a Linuxcnc installation
The image is deliberately minimal because of the limited resources of these single board computers.
1 year 10 months ago #316935 by Cant do this anymore bye all
I concur with Rod, and will also state again that the linuxcnc images are not meant to be daily drivers.
The partition managers and such are not required to run a cnc machine.
Forget about the Raspberry Pi utils, this is a Debian installation, apart from the kernel and overlays.
I’d stay away from anything KDE, there will be libraries and other stuff installed that will be basically only for that particular application. GTK apps will be far lighter weight.
The Linuxcnc images are purely for running a cnc machine, if you need want other programs you are free to install what you want but don’t hope them to be included in the supplied image.
1 year 10 months ago #316940 by rodw
We don't use it but I have in the past.. Debian do offer an image for the pi
raspi.debian.net//
Its very minimal (command line only), You can build it up to run linuxcnc. Its interesting to read their FAQ page for reasons why they don't include configuration packages and why they don't include a build for the Pi5
Our approach to compile the Pi kernel instead of using Debian's solves some issues but we follow their minimalisitc approach. be thankful we provide menu-config :)
The following user(s) said Thank You: resmond
Moderators: KCJ, Lcvette
Time to create page: 0.242 seconds
