coolant mist pulses
15 Nov 2024 18:23 #314548 by PCW
Replied by PCW on topic coolant mist pulses
Yes, there's another "not" component instantiated somewhere.
probably best to change the loadrt not command in the main hal
file so it instantiates all the "not" components needed
The following user(s) said Thank You: Ismacr63
15 Nov 2024 18:36 #314549 by PCW
Another trick would be to sidestep the "not" issue
and use another (hopefully unused) function to get
the not functionality:
loadrt siggen
addf siggen.0.update servo-thread
setp siggen.0.frequency .1     # 10 second period)
loadrt oneshot
addf oneshot.0 servo-thread
setp oneshot.0.width 2           # 2 second on time
loadrt logic personality=2050
addf logic.0 servo-thread
setp logic.0.in01 true
net cool-trigger siggen.0.clock oneshot.0.in
net coolant-out oneshot.0.out [some_parallel_port_pin]
net coolant-on logic.0.in-00
net gate-coolant logic.0.nand  oneshot.0.reset siggen.0.reset  # when coolant is off, reset both siggen and oneshot
also note that "coolant-on" is a made up signal name, you need to replace it with the actual
signal name used in your configuration for this function
15 Nov 2024 19:01 #314550 by Ismacr63
Replied by Ismacr63 on topic coolant mist pulses
loadrt siggen
loadrt oneshot
I made it work with the "NOT"
I changed
Loadrt not for loadrt not count=3 in main hal.
In postgui hal I have commented loadrt not
I also realized that I didn't change the name of "coolant-on" to the one in my configuration.
Now it works perfect.
What for any of you is a minute for me turns into days T_T
but I really like it because I'm learning a lot about linuxcnc.
thank you very much for the help.
15 Nov 2024 19:28 #314553 by PCW
LinuxCNC/HAL is very powerful and customizable once you get
over the learning curve, looks like you are getting there...
The following user(s) said Thank You: Lcvette, Ismacr63
Moderators: KCJLcvette
Time to create page: 1.012 seconds
