Cant change from develop to stable
21 Nov 2024 23:27 #315007 by Sternfox
Cant change from develop to stable was created by Sternfox
Hi I have installed Probebasic, each time i open it, i get the message about being in develop mode, when i go to change the repos to the stable mode, it is already down as stable mode!
I have tried to update Probe basic and get the following error.
Building module:
Cleaning build area...
'make' all KVER=6.1.0-27-rt-amd64...(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.1.0-27-rt-amd64 (x86_64)
Consult /var/lib/dkms/rtl8814au/4.3.21/build/make.log for more information.
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
dkms: autoinstall for kernel: 6.1.0-27-rt-amd64 failed!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
Failed to process /etc/kernel/header_postinst.d at /var/lib/dpkg/info/linux-head
ers-6.1.0-27-rt-amd64.postinst line 11.
dpkg: error processing package linux-headers-6.1.0-27-rt-amd64 (--configure):
 installed linux-headers-6.1.0-27-rt-amd64 package post-installation script subp
rocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-rt-amd64:
 linux-headers-rt-amd64 depends on linux-headers-6.1.0-27-rt-amd64 (= 6.1.115-1)
; however:
  Package linux-headers-6.1.0-27-rt-amd64 is not configured yet.
dpkg: error processing package linux-headers-rt-amd64 (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
many thanks
  • Moderator
  • Moderator
25 Nov 2024 19:43 #315248 by tommylight
Replied by tommylight on topic Cant change from develop to stable
Failing to build the kernel due to issues with the RealTek DKMS drivers:
I would try removing the DKMS driver, install QtPyVCP then install the driver again.
29 Nov 2024 10:56 #315527 by rodw
Replied by rodw on topic Cant change from develop to stable
the dkms drivers require linux-headers for your kernel version. I don't think its installed.
The dkms system compiles the driver for kernels if they are changed or upgraded and the headers are required
The following user(s) said Thank You: Lcvette, Sternfox
Moderators: KCJ, Lcvette
Time to create page: 0.082 seconds
