(Solved)NameError: name 'tool' is not defined on Probe_Basic_Lathe
  • EndCNC
  • EndCNC's Avatar Topic Author
  • New Member
  • New Member
07 Dec 2024 18:38 - 08 Dec 2024 10:23 #316205 by EndCNC
Hello,
I have the following problem: Every time I want to change a tool, I get this error message
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 1453, in update_tool
    self.tool_bit_actor = ToolBitActor(self._datasource)
  File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/tool_actor.py", line 423, in __init__
    points.InsertNextPoint((self.tool.xoffset, 0.0, -tool.zoffset))
I completely rebuilt the system as described in Git. Everything seems to be working great, except for changing the tools. Does anyone have an idea what it could be?Greetings, Sebastian
Last edit: 08 Dec 2024 10:23 by EndCNC.
  • EndCNC
  • New Member
  • New Member
08 Dec 2024 09:49 #316236 by EndCNC
Problem solved! The solution was a clean uninstallation and then a complete reinstallation.
The following user(s) said Thank You: Lcvette
09 Dec 2024 15:25 #316343 by Lcvette
Glad you got it sorted, I think there is a patch for linuxcnc versions after the lockdown 2.9.3 for this issue, it was discussed in a previous thread I think.
Moderators: KCJ, Lcvette
Time to create page: 0.094 seconds
