Probe_Basic Bugs?
1 year 10 months ago - 1 year 10 months ago #317361 by Lcvette
Replied by Lcvette on topic Probe_Basic Bugs?
instead of using the letter, use the joint number and see if this resolves! change the word axis: to joint: also
machine.home.joint:0
machine.home.joint:1
machine.home.joint:2
machine.home.joint:4
machine.home.joint:5
Last edit: 1 year 10 months ago by Lcvette.
1 year 10 months ago #317364 by Lcvette
try that and let me know if it works, if so you will need to also adjust the unhome buttons in the WCS sidebar tab to use joint numbers
and you may want to add your 4th/5th axis buttons there as well.
1 year 10 months ago #317423 by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic Bugs?
thx i will try it
1 year 10 months ago #317428 by Lcvette
please let me know how it goes
1 year 10 months ago - 1 year 10 months ago #317602 by CNC_ANDI
ok update...today i got a working 3 and a working 4 axis plot to my machine configuration...the 3 Axis working plot is just fine all buttons working correctly.but in the 4th axis plot the Zero B button did not work. DRO works correctly to my b axis.and when i do single ref for all axis (not refall button) i cant jog my machine and become a error like this from the attachment.
is this an error from porbe_basic or from linux_cnc? iám running linux cnc 2.9.0 pre ...
edit: I solved the Zero B error... G10 L2 P{ch[0]} B0.0 needs to be G10 L20 P{ch[0]} B0.0
Last edit: 1 year 10 months ago by CNC_ANDI.
The following user(s) said Thank You: Lcvette
1 year 10 months ago #317651 by Lcvette
Excellent news!
Moderators: KCJ, Lcvette
Time to create page: 0.312 seconds
