Rack Tool Changer
04 Feb 2025 15:01 #320655 by jjdege
Replied by jjdege on topic Rack Tool Changer
Hi, sorry, do you mean something like this ?
04 Feb 2025 18:38 #320673 by Lcvette
Replied by Lcvette on topic Rack Tool Changer
I think he was referring to the integration in probe basic
04 Feb 2025 22:13 #320696 by Martin.L
Replied by Martin.L on topic Rack Tool Changer
Yes, it will be really helpful if you can share this sample and how it's implemented step by step, even if the topic is about probe basic rack implementation it should merge on it somehow
04 Feb 2025 23:55 #320702 by Martin.L
Are these a good starting point and still viable or are obsolete? the racktoolchange sample readme is pointing to an old EMC patch..
github.com/LinuxCNC/linuxcnc/tree/master...emap/rack-toolchange
github.com/LinuxCNC/linuxcnc/tree/master...h-tool-length-switch
05 Feb 2025 01:02 #320707 by jjdege
ok, the integration in probe basic is deeper, not my thing,
mine is only a macro one
05 Feb 2025 02:19 #320710 by Martin.L
By macro you mean it's just a gcode sequence?
05 Feb 2025 03:04 - 05 Feb 2025 03:07 #320713 by jjdege
yes exactly, a sequence of gcode linked to the buttons on the gui
with cycle stop and error message in case something goes wrong
Last edit: 05 Feb 2025 03:07 by jjdege.
05 Feb 2025 03:29 #320715 by Martin.L
Can you share the files? Using Gcode how LCNC know where are the XYZ coordinates of a tool?
05 Feb 2025 05:22 #320723 by Lcvette
in probe basic the user parameters you enter for things like probing and tool setting etc are stored in the var file and then can be called upon in subroutines/macros. in this regard probe basic will have a user setup page where you can enter in parameters that would determine rack location (along X axis or along Y axis), axis row centerline position, pocket spacing, number of pockets, pickup height, clearance height, special considerations such as air blast activation, dust boot clearance motion activation, tool touch off options etc.
I spent some time last night and will spend some more time this morning working on adding multiple atc options in the ini to load either not atc tab, carousel atc tab or rack atc tab. i got most of that sorted last night but want to refine it a bit and then i will start work on the actual rack graphics and setup page and subroutines.
05 Feb 2025 08:07 #320748 by Martin.L
Nice! If you need someone to play with it I'm here
Moderators: KCJ, Lcvette
Time to create page: 0.501 seconds
