Rack Tool Changer
1 year 8 months ago #321083 by Lcvette
Replied by Lcvette on topic Rack Tool Changer
the new implementation of the rack atc will handle all toolchange motion. i just finished working out the user parameter setup page, this will give users 8 unique machine mechanical rack row configurations to successfully implement directly from the rack setup page in the ui.  i wrote a subroutine that will calculate which rack ID type based on 3 user XY machine coordinate position inputs for the center point of (pocket 1), (pocket 2) and (pocket 1 clearance).  that rack id will be used in the remapped atc macros to dictate all of the motion and directional requirements for knowing which direction the rack is positioned on the machine, (along X or Y axis), which direction the pocket numbers are ascending from pocket 1 position, and which direction to remove the tool from the fork.  this along with an ini setting for the pocket count, the traverse feedrate for the atc motion, the z clearance height and z load height will give the atc macros the required motion parameters it needs.
users will still need to properly setup their hal for IO such as drawbar, spindle orient, any safety sensors etc, but this will get the user an easy to use atc with minimal setup difficulty!
The following user(s) said Thank You: Martin.L
1 year 8 months ago #321093 by Martin.L
Replied by Martin.L on topic Rack Tool Changer
I can't thank you enough for your effort. This is a real time saver, I've spent hours just to understand what's behind a possible implementation of an atc.
Guess PB is going to be one of the most used GUI because it is cutting all the hardest parts to setup.
The following user(s) said Thank You: Lcvette
1 year 8 months ago #321100 by Lcvette
yeah this implementation has been a long time coming, it wasn't a small undertaking and is still a work in progress, but it should really help users get going! pretty jazzed about it!
1 year 8 months ago #321283 by yoshimitsuspeed
Replied by yoshimitsuspeed on topic Rack Tool Changer
Yes this is awesome. I hope to get around to setting it up in the next few days.
Is this on the stable repo now or should I switch to dev?
1 year 8 months ago #321288 by yoshimitsuspeed
Realizing now I might have misinterpreted the above posts as meaning a useable version was available.
If that's not the case I'm curious how long it will be till it might be ready?
Not trying to rush things if it's not done, just trying to get a gauge on ETA after realizing maybe it's not already in the repo or ready for release.
1 year 8 months ago #321299 by Lcvette
Steady work is happening on it at the moment, but it will be a week or two probably before we shake out everything and merge to the development repo
The following user(s) said Thank You: Unlogic, Martin.L
Moderators: KCJ, Lcvette
Time to create page: 0.331 seconds
