Keyboard shortcuts
- Sternfox
- Thank you received: 7
16 Jan 2025 12:06 #319114
by Sternfox
Keyboard shortcuts was created by Sternfox
Hi all, im nearing the end of my retrofit build. I am wanting to use some keyboard shortcuts. Not for jogging!
I want to be able to select individual axis for mpg jogging using a keyboard shortcut. Also select things like mpg reaolution. Is this possible?
Thanks in advance
Thanks in advance
- programador
- Thank you received: 5
16 Jan 2025 12:11 #319115
by programador
Replied by programador on topic Keyboard shortcuts
Good morning friend, I know some shortcut keys for LinuxCNC, one day I will see if there is the possibility of creating a custom shortcut key and then I will post it here.
Keystroke Action Mode
F1
Toggle Emergency Stop
Any
F2
Power On/Off Machine
Any
`, 1..9, 0
Set Feed Override from 0% to 100%
Varies
X, `
Enable First Axis
Manual
S, 1
Enable Second Axis
Manual
Z, 2
Enable Third Axis
Manual
A, 3
Enable Fourth Axis
Manual
L
Select Jog Increment
Manual
C
Continuous Jog
Manual
Control-Home
Execute Home Sequence
Manual
End
Touch Off: Set G5x Offset for Active Axis
Manual
Left Right
Jog First Axis
Manual
Up Down
Jog Second axis
Manual
Pg Up, Pg Dn
Jog third axis
Manual
Jog fourth axis
Manual
O
Open file
Manual
Control-R
Reload file
Manual
R
Play file
Manual
P
Pause execution
Auto
S
Resume execution
Auto
ESC
Stop execution
Auto
Control-K
Clear background graph
Auto/Manual
V
Switch between preset views
Auto/Manual
Shift-Left, Right
Fast X axis
Manual
Shift up, down
Fast Y axis
Manual
Shift-PgUp, PgDn
Fast Z axis
Manual
Toggle real/commanded
Any
Toggle relative/machine
Any
F1
Any
F2
Any
`, 1..9, 0
Varies
X, `
Enable First Axis
Manual
S, 1
Enable Second Axis
Manual
Z, 2
Enable Third Axis
Manual
A, 3
Enable Fourth Axis
Manual
L
Manual
C
Continuous Jog
Manual
Control-Home
Manual
End
Manual
Left Right
Jog First Axis
Manual
Up Down
Jog Second axis
Manual
Pg Up, Pg Dn
Jog third axis
Manual
Jog fourth axis
Manual
O
Open file
Manual
Control-R
Reload file
Manual
R
Play file
Manual
P
Pause execution
Auto
S
Resume execution
Auto
ESC
Stop execution
Auto
Control-K
Auto/Manual
V
Auto/Manual
Shift-Left, Right
Fast X axis
Manual
Shift up, down
Fast Y axis
Manual
Shift-PgUp, PgDn
Fast Z axis
Manual
Any
Any
- Lcvette
- Thank you received: 784
16 Jan 2025 14:19 #319124
by Lcvette
Replied by Lcvette on topic Keyboard shortcuts
this would be in main linuxcnc forum most likely i think for information on key assignment for better results. its not really dealing with the ui beyond controlling functions already preestablished inside linuxcnc that the ui connects too.
Moderators: KCJ, Lcvette
Time to create page: 0.072 seconds
